Results 1 to 4 of 4
Thread: Ae71 small port conversion tacho help
    Senior Member JinxD's Avatar
    Ash
    Default Ae71 small port conversion tacho help
    Hey guys I've just finished this conversion. We would like to use the stock tacho. However, I'm not sure how to connect it up. Afaik you take a loop from the small port coil on the negative side to a wire on the stock tacho.
    Correct me if I'm wrong please.
    Does anyone know which wire it is that I need to tap into colour and location would be good. Or if anyone knows which on it is behind the dash I can get to it there also. Thanks in advance.
    Alex
    Wagga Wagga
    I do know how to do it as I did it with my old smallport conversion, only thing is off the top of my head I can't remember the colour of the wire. When I get home from work, I'll have a dig around and see if I can find a photo or if not, see if I can remember which one it was in the engine bay.
    I think off the top of my head it was a thin black wire from the drivers side wiring loom. (Where it comes through the guard into the engine bay)
    Alex's 4AGTE KE70
    Or so was thought...
    Can confirm it is a thin black one on the ke70.... Which you'd think is the same on the ae71
    Alex
    Wagga Wagga
    Had a quick glance last night to see if I could spot that wire. Unfortunately I have all those wires now cut off and tucked away in some conduit. I am now fairly certain it was a thin black one knowing that Matt thinks the same.
    If you wanted to do a test, get a length of wire and connect it to the -ve side of the coil and just tap the wire against each of the other wires coming out that side of the engine bay. One will make your tacho jump
    Alex's 4AGTE KE70
  1. Big Port To Small Port Conversion???
    By ae8616v in forum Technical - Questions
    Last Post: 18th May 2011, 07:34 PM
  2. Replies: 0
    Last Post: 11th July 2010, 08:50 PM
  3. AE71 conversion bits, Tacho dash
    By Philbo in forum Car Parts For Sale
    Last Post: 17th May 2010, 08:39 PM
  4. ae71 stockos, small port ecu, standard borgie
    By KE70briskev in forum Car Parts For Sale
    Last Post: 14th January 2008, 09:59 PM
  5. Replies: 2
    Last Post: 3rd January 2007, 08:52 AM
