Results 1 to 10 of 16
Thread: Safety 21 cages
    Senior Member dansomerville's Avatar
    Jun 2011
    Daniel
    Townsville
    Default Safety 21 cages
    Hey I know of Cusco Safety 21, 5 point half cage for sale in good condition at a good price. I'd like to know if they were made differently for the different variations of 86, are the cages different between coupe and hatch or do they fit both?
    And before I get flamed, yes I understand I probably don't need a cage, these cages are not able to be Cams approved, and I can probably get a better cage at a reasonable price elsewhere. But for the money, this purely for the wank factor, what of it.
    Thanks, Dan.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    at least your honest
    Moderator Frak's Avatar
    Jamie
    Cusco cages and Safety 21 were 2 different companies, safety 21 was bought out by Cusco, you will find the Cusco ones are chromoly and the safety 21's are mild steel. They do many different types BUT the important thing to be aware of is the front part of the cage, if it is a 'dash escapement' type it will have a double bend around the dash and will not be allowed to be used in any event sanctioned by cams the through dash type have one bend and are fine, the double bend type can currently be used in drift events but I believe this is changing(or might already of). If you are doing sprints they will not allow the front part of a 'dash escapement'(this is what Cusco call it), but the half cages are fine. If you get a full cage and it has a double bend and want to run it for 'wank factor' when you do a sprint etc just take the front part out. From what you have written it looks like you want a 5 point which is half which will be fine for sprints.
    Hachiroku since 1994
    Jun 2011
    Daniel
    Townsville
    Hey Frak thanks heaps, that's really helpful. It's just a 5 point half cage, so no forward legs. Whether or not it's a Pre Cusco one I'm not sure. Do you know if the designs where made to accommodate both coupe and hatch's though, mounting points the same?
    I use the term 'wank factor' loosely it probably would be beneficial if I attempt to put the thing on it's lid at some stage around the track or at a hill climb. I have big doubt's bolt in cages do much for body rigidity. But it will only cost me a drive to Warwick, hence wanting it just because I can haha.
    Jamie
    Daniel, I don't thin there is a difference in the safety 21/cusco cages between hatch/coupe, they don't extend in to the hatch area and they bot up to the rear arches, which I imagi ne are in the same place. Cusco chromolys are usually painted cusco blue from factory and safety 21s are black, I think you will be suprised how much extra rigidity it adds contrary to popular belief.....
    Veteran johl's Avatar
    Johl
    are you going to weld in proper mounts to bolt it to? imo the supplied mounts that you bolt underneath the floor are insufficient and would just push through the floor in a bad roll over
    Jun 2011
    Daniel
    Townsville
    Oh ok I didn't think they would be different. Well this one is black, and looks like it has blue padding, I've only looked at it breifly. Do they really make much of a difference with just the four points? I assumed they wouldn't do that much without gusseting to the body?
    I agree with you, I think in a decent roll over they would just push through, if was going to weld it though I'd probably just buy an AJPS weld in. But welding the bottom mounts would still work without having to weld the cage in permanently if I get hassled by the poleece.
    Veteran timbo's Avatar
    Tim?
    Wild West
    For what it's worth I have the back half of a Safety 21 7 point cage, and call me crazy but I think they do add a little to the cars structure. I've been in a few other Corollas now and they do feel different. Wank factor or not they will aid you in the worse case scenario of rolling and that's why I never got rid of mine.
    Jamie
    Tim I totally agree with you, you will feel a difference, as to wether it will do anything in a roll over, over thear years I've seen plenty of dodgy bolt in ally cages that have save cars in roll overs, bit of denting of roof/a pillar, c pillar etc but stopped when it got to cage. Years ago when I fitted a 7 point I had to back off the rear shocks to stop it jumping around over bumps, it didn't do it before the cage went in. Even Porsche use bolt ins :p
    Johl
    at worst it would be comparable to a bolt in rear strut brace so i can easily see some benefits of running a bolt in cage even just for rigidity
  1. safety 21 5 point halfcage
    By Dazzla86 in forum Car Parts For Sale
    Last Post: 24th June 2012, 02:40 AM
  2. QLD - Cusco Safety 21 Half cage - near new
    By kaibeecee in forum Car Parts For Sale
    Last Post: 27th September 2010, 01:20 PM
  3. AE86 Safety 21 7 point cage
    By jaz_ae86 in forum Car Parts For Sale
    Last Post: 11th November 2009, 09:50 PM
  4. Safety 21 6 Point Rollcage
    By delazy in forum Car Parts For Sale
    Last Post: 4th September 2007, 09:34 PM
