Results 1 to 3 of 3
Thread: 4age no start?
    Sep 2011
    Canberra
    Default 4age no start?
    hi everyone,
    i have a ke7o with bigport 4age.
    i put a new battery in it on sunday and started the car no worries.
    when i went to start it on monday i couldnt get spark, the car would turn over but nothing else.
    with a test light i checked the power to the coil pack, good earth but nothing getting to the positive terminal.
    i then run a solid positive wire striat to the postive on the coil pack which gave me spark, but also started the fuel pump but the car wouldnt fire?
    any help would be greatly appreciated as i hope to have the car on the track in a fortnight. :/
    Thanks
    Go through the wiring guide that is posted up on here , and check one wire at a time...
    ECU has power at B , +B terminals
    Injectors have power
    Coil has power
    Fuel Pump Has power
    Earth strap on the inlet manifold is connected and TIGHT
    Check those and you should find it is one of them.
    Sep 2011
    Canberra
    ok thanks,
    is this said wiring guide?
  1. 4age won't start
    By Brokenships in forum Technical - Questions
    Last Post: 1st June 2012, 11:10 PM
  2. ke70 4age conversion wont start
    Last Post: 28th September 2011, 09:24 PM
  3. 4age retards ignition at start up sometimes
    By biggo in forum Technical - Questions
    Last Post: 21st October 2010, 02:19 AM
  4. 4AGE 20v Help! - won't start!
    By DAMO46 in forum Technical - Questions
    Last Post: 5th March 2010, 06:53 PM
  5. Where to start??? need help with 4age conversion
    By Drift_Dan in forum Technical - Questions
    Last Post: 19th January 2010, 08:21 PM
