Results 1 to 10 of 11
Thread: O2 sensor question
    Veteran haveaparty's Avatar
    Mar 2010
    Brett
    Crestmead
    Default O2 sensor question
    Hey everyone. Posting this up for our mate kyleunwin.
    He has a small port engine with ecu and loom. His question is in regards with the o2 sensor. After a quick search I'm still not 100% sure.
    Does any o2 sensor work or do u need a specific one for his engine. Also. Which is the o2 sensor plug on he engine loom. My research says its a single wire yellow plug?? Also. His extractors require a flange type sensor and not the screw in type. Will this matter or will he hav to plug that one up and get a new hole drilled??
    i havnt looked at the car yet to look for myself. But any help would be appreciated.
    Mar 2011
    Ali
    Not sure if its a good idea, but I ditched the sensor all together when I bought one of Kaizen's 16V extractors on a stock bigport ecu and didn't have a drama that I noticed?
    I'm sure if I had the check engine light wired it would have flashed a code.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Not sure if it would give you a code or not, but fuel economy wouldn't be anywhere near as good. Any single wire o2 is really only used for trimming fuel when cruising and at part throttle. Worth wiring in for a road car definately.
    Mar 2010
    Brett
    Crestmead
    Thanks guys. Will pass on the info
    Veteran timbo's Avatar
    Tim?
    Wild West
    I'm running a smallport O2 sensor on my smallport with bigport jap loom. All it needs to be is a single wire type, just so happens that a smallport plug is the same as bigport.
    run an 02 sensor otherwise it'll run a fail safe map and on the rich side, even richer than normal... A single wire universal one will do, 02 sensors are a 100k service item but no one ever changes them.
    I've also heard it knocks a bit of timing advance out as well, but haven't been able to confirm that myself.
    As for the check engine code, it only displays once you put it into diag mode. Code 21 from memory.
    And get kyle to post on here himself not unless he has no hands or is busy doing his hair in the mirror or something....
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    universal single wire O2 sensor, if kyle needs one, i have one from mine
    Mar 2010
    Brett
    Crestmead
    Thanks guys. He would of himself but he was busy taking selfies and doing his hair. Also has no access to the site at the moment.
    Aug 2010
    Geoff
    mt dandenong
    o2 sensor is 5 on check engine light, worth fitting too.
    mine without 02 gets 40L per 400k's, with gets 32L with 450k's
    Nov 2010
    Peter
    Vic
    Northern suburbs
    I have an aftermarket generic replacement on my small port, its a screw in type, but came with a two bolt flange adaptor as well. Heaps shorter than a factory unit too. Was about $80 from Bursons I think. In the loom, it's a shielded black wire from memory.
  1. O2 sensor mounting
    By ke_70_blue in forum Technical - Questions
    Last Post: 8th April 2012, 01:10 AM
  2. O2 sensor, what type do i need?
    By danny_ke70 in forum Technical - Questions
    Last Post: 15th October 2010, 07:24 PM
  3. o2 sensor for adaptronic -
    By NIZLAH in forum Technical - Questions
    Last Post: 16th May 2009, 12:30 PM
  4. O2 Sensor Plate
    By jason in forum Technical - Questions
    Last Post: 11th March 2007, 08:57 PM
  5. o2 Sensor 4AGZE
    By SKREMN in forum Technical - Questions
    Last Post: 27th October 2006, 12:26 PM
