Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Ae71 4age conversion
    Jun 2009
    Imran
    St Clair
    Default Ae71 4age conversion
    Hey Guys
    Doing a 4age conversion in my ae71 and have read a lot about changing the pedal box to ae71 pedal box because it's hydraulic , this may sound stupid but does a hydraulic clutch use a master cylinder ? If so does a ae71s clutch master cylinder sit in the engine bay ? Any help would be appreciated , thanks guys
    Veteran stahlz_ae86's Avatar
    Paul
    Yes, clutch master cylinder bolts to the firewall in the engine bay. I assume you've got an auto AE71? You will need an AE71 manual pedal assembly or a modified unit (Jordo - KE conversions site sponsor on here can help, has a template for drilling the holes also).
    Jun 2009
    Imran
    St Clair
    Thanks heaps mate , it's manual but it has a mechanical clutch , what do you think the best option would be ?
    Paul
    To convert to Hydraulic you will either need a manual AE71 pedal assembly or contact Jordo for modifying yours.
    Senior Member J0RD0's Avatar
    Feb 2010
    Jordan
    you sure its an AE71? thought KE70's only came out with the cable clutch if thats what your refering to?
    cheers for the referal stahlz
    THE EVOROLLA none of this SR shit . . . EVO 7 powered bitches
    https://www.facebook.com/KeConversions
    KE conversions - making your conversion simple
    4AGE CA18 SR20 BEAMS 1UZ to KEXX mounting kits and hydraulic pedal box's available
    Ke70's have cable clutch, ae71 hydraulic... Next to your brake booster you will have another reservoir to fill up with fluid...so 2 caps to remove in the engine bay = hydraulic clutch.
    Will you be doing this conversion yourself?
    Jun 2009
    Imran
    St Clair
    Thanks for all the info guys , there isn't another cap and there is a cable that goes from my firewall to my gearbox so I'm assuming it's cable
    As for the conversion a mechanic will be doing it from home
    Aug 2010
    Geoff
    mt dandenong
    is your motor current 4K? does it say ae71 on the chassis code? sounds like someone put in a 4k into your car if its a ae71 with a cable clutch
    Jun 2009
    Imran
    St Clair
    I'll take a photo of the engine bay and post it
    definately sounds like a 4k...
  1. 4age bigport 16v conversion for KE70/AE71
    By leigh4110 in forum Car Parts For Sale
    Last Post: 6th July 2010, 06:53 PM
  2. FS: 100kw 4age engine conversion in ae71
    By marlon in forum Cars for Sale (Toyota Only)
    Last Post: 31st March 2009, 08:42 PM
  3. WTB: AE71 Manual conversion parts + 4AGE
    By thesim in forum Cars or Parts Wanted
    Last Post: 15th January 2009, 07:45 PM
  4. Putting a 4age into my ae71 + manual conversion
    By Ashley86 in forum Technical - Questions
    Last Post: 12th February 2008, 05:46 PM
