Results 1 to 7 of 7
Thread: Lower control arm identification
    Walte
    Goldcoast
    Default Lower control arm identification
    Hey guys/gals
    I have extended lower control arms in my AE and the balljoints and bushes are flogged out so I'm going to replace them
    The problem is im not sure if they are sigma or xt130 or ....
    I'm hoping someone on here can tell me by the length
    The length is 395 from outer edges. I can get photos if need be
    Walter
    Mar 2011
    Ali
    Have you got them out?
    Sigma's will have some form of modification to the bush to make them fit - usually ground down on one end and easily picked.
    Some Sigma's (the really long ones) have a bolt in ball joint, where as the early sigmas are press fit.
    XT130's are press fit with cir-clip.
    Walte
    Goldcoast
    I went with what you said and I assumed they were the xt130's as it has a cir-clip and there is no noticeable grinding marks
    It does look a little dodgy at the rear of the control arm but to me it just looks like its how they were casted
    I purchased a set of ball joints and bushes
    I went to press the ball joints in and the hole on the contol arm is about 1mm to small to press the new ones in and the bushes looked a tad to small also
    Ill take some photos and place them up tomorrow to see if I can get this sorted
    Mar 2011
    Ali
    Sorry mate, didn't mean to give you a bum steer.
    Sigma's also need a touch up on the crossmember end with a grinder, so sounds like could be sigma's.
    Photo's would be the go.
    Walte
    Goldcoast
    All good man I should have put pictures up
    Here's a few, hopefully they can help identify them
ID:	27410Click image for larger version.
ID:	27412Click image for larger version.
    Mar 2011
    Ali
    look like GE/GH sigma's to me.
    If your replacing the bushes there are 2 different types.
    Make sure you get the right ones.
    Walte
    Goldcoast
    They did end up being GE Sigma's
    Thanks heaps for the help!!
  1. Lower Control Arm- Measurments & Compatibility
    By hitoriko in forum Technical - Articles
    Last Post: 2nd July 2012, 02:36 PM
  2. Replies: 22
    Last Post: 25th August 2011, 03:15 PM
  3. WTD: lower control arm!
    By sprintrphile in forum Cars or Parts Wanted
    Last Post: 18th August 2009, 09:50 PM
  4. lower control arm bolt, getin it back in
    By duurs in forum Technical - Questions
    Last Post: 14th November 2007, 09:51 PM
  5. lower control arm problems.
    By Trucka 115 in forum Technical - Questions
    Last Post: 25th September 2007, 12:43 PM
