Results 1 to 8 of 8
Thread: 4AGZE pistons and rods into 4AGE bigport
    Member Alexrex7's Avatar
    Jul 2010
    Alex
    Qld
    Goldy
    Aussie
    Default 4AGZE pistons and rods into 4AGE bigport
    Motor, 4AGE 16V bigport
    Car, Toyota KE70
    Bit of mixed info in my searches so just checking are 4AGZE pistons and rods a straight bolt in job into a 4AGE 16V as in the same bore and same size diameter crank? Also thinking about running a SR20 redtop turbo as i can get one dirt cheap at the moment only wanting around 200hp any opinions on how they go on a 4AGE would be great too. thanks
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    There's two different big end journal sizes for 4age's, bigports are 40mm and all the later engines use 42mm big ends. I'm not sure if the bigport gze's used the smaller journal rods or not, but easy enough to check really.
    Jul 2010
    Alex
    Qld
    Goldy
    Aussie
    yeah it sucks cuz theyre on ebay and i cant measure them all i know is they are AW11 4AGZE type dont want too take a risk and buy them to find the journal size is differnet
    Mar 2011
    Mt Dandenong
    I would never reccomend anyone buy second hand rods anyway, who knows what kind of life they've had or why the engine came apart in the first place. Plenty of reasonably priced new rods out there, little bit more money up front but for peace of mind you know you won't have any issues.
    Jul 2010
    Alex
    Qld
    Goldy
    Aussie
    Yeah lol i know not to trust stuff like that but they are pretty much new still and dirt cheap. So can anyone confirm for sure the size of the bigport journal rods compared to AW11 4AGZE? Cheeers
    Veteran timbo's Avatar
    Tim?
    Wild West
    I have some late model rods out of a smallport (I'm selling) which are the same as GZE. I want to get rid of them in favor of something lighter but they are good for turbo use etc, but they are definitely 42mm.
    Member geoff's Avatar
    Geoff
    Glen Waverley
    Quote Originally Posted by Alexrex7 View Post
    AW11 4agze has the 7 rib block which is the later version (4agze was only an option post 87), so if what jimmee said was true, then it would probably be the 42mm big end. As far as i know the block is identical between the 7 rib bigport and the 4agze
    Veteran Skylar's Avatar
    Ken
    yall are doing it way wrong.
    GZE are 42mm rod journal. Later model Bigports ("red and black" top) had a 7 rib block. 101 GZE has a different block to AW11 GZE but pretty sure AW11 GZE is same is AE92 GZE.
    DO you have a 7 rib bigport Alex? If so, it'll work. If not rebuild the motor and just boost it. or don't even bother. 200hp is nothing for a stock block 4a. It'll last as long as it's in fairly good condition and the tune is good. Garage dori had some pretty hagard setups and they used to last a long time. All the good info is gone from that site though.
  1. 4agze pistons and rods
    By jimmy19650 in forum Technical - Questions
    Last Post: 10th April 2010, 02:27 PM
  2. WTB : 4agze rods and pistons asap
    By trd4ag in forum Cars or Parts Wanted
    Last Post: 7th April 2010, 10:09 PM
  3. FS: 4agze early model smallport pistons and rods
    By Dongaz in forum Car Parts For Sale
    Last Post: 3rd August 2009, 12:53 AM
  4. WTB 4agze pistons and rods
    By AE86dori in forum Cars or Parts Wanted
    Last Post: 29th July 2008, 06:02 PM
  5. Replies: 6
    Last Post: 15th July 2008, 08:28 PM
