heaps cheap! will go quick
Engine was rebuilt at the start of the year. strong motor, all test ect welcome.
Engine specs: ae92 ze (afm version)
Full rebuild.
hks 1.5mm metal headgasket
arp head studs ( oil feed hole in head machined out so the studs dont block the oil feed)
valve re-grind
new seals everywere
Tomei pon cams (264in/ex 8.1 lift)
gates racing timming belt.
t-3 175mm pully turning the sc12.
supercharger oil replaced
Engine comes with a BOLT IN greddy v mount intercooler set up with stainless piping.
Sold as a package ie. engine, loom ecu. Dose not come with flywheel/clutch, zuast. always run on royal purple.
Price options
$3000 as is
$2500 without cams.
$2200 without cams/v mount.
pm me for number
Pics of the Vmount? Sell separatly? Can supply 1g fmic modded to fit e7 if engine buyer wants...?
that's the only pic i have when i was making it.
What are you doing with extractors?
You want ?
Also keen on the extractors If your gettin rid of them, if not where did you get them from?
Also, motor is in car and runing.
Offers ? Don't be shy
Did you get my pm mate?
