Results 1 to 6 of 6
Thread: Steering rack/tie rod question
    Sutherland
    Default Steering rack/tie rod question
    Hi guys,
    I used to know this off the top of my head but now can't remember at all.
    I've got LCA's 25mm longer than factory and power steering arms and need to remember what rack end, steering tube and tie rod I need to use.
    I think I used to run XT130 rack ends, RA40 tube and tie rod ends.
    Cheers, Ben
    Veteran timbo's Avatar
    Tim?
    Wild West
    I have RA40's with XT130 LCA's and I'm not sure if they'd reach 25mm, if they do you would't have much adjustment . Maybe a longer "tube" or find something with the same thread pitch etc.
    Adan
    Oxley Park
    Im pretty sure Im running ra60 rack ends, with rose jointed tie rod ends. My control arms would be about 25mm longer than standard also..
    Senior Member JinxD's Avatar
    Ash
    Ra40 tie rod outers
    Any Toyota with a steering box will have steering tubes to suit.
    My lca's are +30mm and I have very short steering arms and there is plenty of thread engagement
    Hair model Jacobxxx's Avatar
    Jacob
    Bangalow
    i run xt130 lcas, custom knuckles, lock spacer and tie rods/rack ends
    Senior Member sam92's Avatar
    Jul 2012
    Wagga Wagga
    I run xt130s, ps knuckles,lock spacer, 86 tie rods and standard rack ends.
    I tried to run ra60 rackends but they were to long and I had heaps of toe in and ran out of adjustment. Stock rackends only just worked.
  1. Inner Tie Rod/Rack End Options
    By JJRC in forum Technical - Questions
    Last Post: 29th April 2015, 01:31 PM
  2. Ke70 - fitting t3 steering arms and tie rod 's
    By nichy in forum Technical - Questions
    Last Post: 28th August 2011, 10:53 AM
  3. Replies: 3
    Last Post: 1st November 2010, 07:44 PM
  4. Steering Lock - Quaife Rack, PS Arms, Tie Rods, Tie Rods Ends
    By SoKAR in forum Technical - Articles
    Last Post: 26th August 2007, 09:18 PM
  5. Brand new AE86 Tie rod end and rack ends
    By tipper86 in forum Car Parts For Sale
    Last Post: 9th April 2007, 09:29 AM
