Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Wilwood big brake kit clearance
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    Default Wilwood big brake kit clearance
    Im looking at buying some work wheels Work Equip 03 but unsure of what disk type to choose.
    Just to confirm I'm thinking of getting the A-Disk type to fit over the wilwood big brake kit.
    Has anyone else done the same?
    thanks Kaan
    West
    Wilwood kit sticks out 5-8mm not much.
    Kaan
    Emerald
    thank you the A-Disk has 10mm brake clearance
    Gone
    Joel
    Picton
    i have never hear of anyone having any issues fitting any type of wheel with the wilwood kits.
    the calliper protrudes 24mm from the rotor mounting face... so if you measure the hub depth and minus 24mm it will give you total calliper protrusion..
    i dont have an 86 hub with me to measure... i did however have an st141 hub.. and the calliper would sit 4mm or so inboard.. so no protrusion.. but just measure an 86 hub to confirm.
    Joel
    Hair model Jacobxxx's Avatar
    Jacob
    Bangalow
    14s or 15s?
    Kaan
    Emerald
    15's I tried some 15x8 -4 superlites with 195/50 re002 on them but running adm setup. But my sis has wilwoods on her car and they're her wheels.
    I was thinking about getting the a-disk 15x9 -3 with similar tyres
    Glenn ke_70's Avatar
    Clay
    Barossa!
    15's will bolt up both a and o disk.worst case would be 3mm spacer.
    i use o disk 14x8.5 -22 equip 03's, but i need an 8mm to clear the bolts. on the back of the rim.
    Gone
    Joel
    Picton
    Quote Originally Posted by Jacobxxx View Post
    14s or 15s?
    Haven't heard of anyone successfully fitting 14's with the wilwood kit yet
    Jacob
    Bangalow
    My AE86 has willwood kit and i'm rolling 14's.
    Clay
    Barossa!
    i use 14's with the t3 wilwood setup
  1. Replies: 31
    Last Post: 8th April 2014, 12:38 PM
  2. Wilwood T3 AE86 Big Brake Kit
    By sundee in forum Spirited Drive
    Last Post: 11th November 2012, 10:41 AM
  3. (VIC) Wilwood brake kit for AE86
    By yian in forum Car Parts For Sale
    Last Post: 5th October 2010, 12:52 PM
  4. FS: [SYD] Wilwood/T3 big brake kit (brand new)
    By willio in forum Car Parts For Sale
    Last Post: 11th May 2010, 06:33 PM
  5. WILWOOD Brake kit
    By myt-16v in forum Technical - Questions
    Last Post: 1st November 2007, 12:11 PM
