O-disk 15" no mod?
The a-disk is looking good right now 15x9 -3 all round
Edit : ordered
well it depends on the wheel...
i've fitted ssr's and hoshinos with no caliper mods only 8mm spacer (less if you get the bolts counter sunk) and as jacob said wed's go straight on, watas probley would too.
the work wheels needed grinding due to the tapered style inner lip that work use, it was about 3mm off the both corners (roughly 50c size) and i gave it 2mm clearence between the wheel and caliper
O-disk 15" no mod?
Edit : ordered
any 15'' wheel will fit...
