Results 1 to 9 of 9
Thread: Stuck + Broken bolts on Longchamps
    Oct 2010
    Dogan
    Tulla
    Default Stuck + Broken bolts on Longchamps
    I've just bought a set of longchamps, as always they needed a goooood clean up. I've taken off nearly all of the bolts except the few that snapped off..
    Now I'm having heaps of trouble trying to push these bolts out.
    Any tips?
    ACT
    Compton
    Drill them out
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    i had the same problem with mine, i let em soak in wd40 and wailed on them with a hammer/punch.
    the problem is the aluminium of the centre corrodes alittle bit and seizes the bolts in.
  • #4
    Oct 2010
    Dogan
    Tulla
    I've tried the wd a few times already, Not one of the bolts have budged. How much effort did smacking them out with a hammer take?
    Damn, I'm not looking forward to drilling them all out..
  • #5
    Aug 2010
    Sutho Shire
    qaulity center punch and a decent wack should get them out,i have done it a couple times,last time i did it 2 a pair of mk3's, i had to do all bolts on both wheels,dont get the punch stuck in the hole thow,thatd be lots of fun
  • #6
    Gone
    Joel
    Picton
    I find using heat is the best way to get out a seized bolt.
    butain torch for a minute around the outside, but not touching the bolt, the straight out.
    If you can put a notch in the end of the bolt, you should be Able to get a flat blade on it and with some heat it should easily come out.
  • #7
    Moderator Sam-Q's Avatar
    Endeavour Hills
    what sort of bolts do you have in them? pics?
  • #8
    Lindsay
    Mackay
    from memory i polished off a 6 pack while i was wailing on them pretty hard.
    i did end up drilling one or two out.
  • #9
    Oct 2010
    Dogan
    Tulla
    Thanks for the tips guys, got them all out.
    I soaked them in some inox lubricant overnight. Inox and a properly fitting punch with repeated light taps and they're all out.
    Sam I wouldn't have a clue what bolts these are but here's a pic of what came out
  • Similar Threads
    1. sTUCK IN 5TH
      By The Enthusiast in forum Technical - Questions
      Last Post: 5th May 2009, 06:43 PM
    2. drums are stuck
      By shinny in forum Technical - Questions
      Last Post: 5th February 2009, 08:04 PM
    3. supercharger stuck
      By Jake_Crawf in forum Technical - Questions
      Last Post: 21st August 2006, 06:29 PM
    4. Removing broken bolts from the block
      By ae71 in forum Technical - Articles
      Last Post: 2nd August 2006, 11:58 PM
    5. Broken engine mount bolts
      By works510 in forum Technical - Questions
      Last Post: 16th July 2006, 09:03 PM
