Results 1 to 10 of 10
Thread: AE86 Close Ratio Gearbox
    Jul 2012
    Michael
    Vic
    Rowville
    Default AE86 Close Ratio Gearbox
    Rare as hen's teeth, I know, but if anyone has one, or knows of one, I "need" it for my KE55 rally car.
    Thanks
    Michael Ward
    Veteran McLEVIN's Avatar
    Nov 2010
    do you have a t50 or need a whole gearbox. if you have a gearbox send it albins they do gears for them.
    MOPAR or no car!
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    TRD also still make the group A close ratio gearset, pretty easy to get still.
    Jul 2012
    Michael
    Vic
    Rowville
    Thanks for the reply, guys... I know the gearsets are still available, but the prices are more than my budget at the moment. Albins quoted $733 /gear ratio (ex tax). Then there's the rebuild of the gearbox on top of that, and the TRD set is around the same price.
    I have one whiny standard box, and a spare box that I purchased earlier this year, that I don't know the condition of yet.
    Glenn
    North Ringwood
    if you buy the trd ratios they include the main shaft and cluster and all of the gears slide on to the shafts
    the 4 gear set up is 3grand which is 1st 2nd 3rd and 5th
    Nov 2010
    thats about the same price as albins
    MOPAR or no car!
    Glenn
    North Ringwood
    yes but you can buy seperate gears if you fuck them ,on the albins they are welded onto your shaft
    plus the toyota stuff is better in my honest opinion all you need it your imput shaft every thing is supplied less bearings
    Senior Member Prime86's Avatar
    Sep 2009
    Brad
    Perth hills
    I looked into this alot myself.
    I found there are advantages for both TRD and Albins gear kits. TRD gear kits are set ratio's and all the gears, shafts are new except the input shaft. The TRD kit is easy to get from someone like RHD Japan for around the $2000 mark.
    Glenn is right about the Albins kit, they grind the gears off, press new gears on then weld them which I thought was a little average myself. They have been doing it along time and I have never heard of there gears having problems through this process. Ablins can make 1st and 3rd gear larger in width making them stronger than the TRD kit and seems to work very well. Another advantage to the Ablins kit is they can make any ratio you want, they have many different selections and they can make a dogbox shift pattern with 1:1 on 5th instead of 4th making for a much closer ratio gearset.
    If this is a full rally car either of the two kits will work well but the syncro's are always going to be an issue if you drive them hard all the time, you will be changing them quite often...Lol. The only way around the syncro issue is to go to a dogbox.
    Maybe some helpful information. Good luck with your search.
    Jul 2012
    Michael
    Vic
    Rowville
    Quote Originally Posted by Prime86 View Post
    <snip>
    Thanks for the helpful advice... I'm leaning towards the TRD box... I had one back in the early 80s in my TE37 replica (KE35 base car)- the box was one of the spares for the Treunos that competed in the '75 Round Australia... it was a nice box, but finally gave up during the State Bank Discovery Trial.
    I'll keep saving my pennies, and keep my eye out in the meantime.
    Sep 2009
    Brad
    Perth hills
    Quote Originally Posted by headhoncho View Post
    No worries Michael.
    Its intreresting what information can be found when you start digging and going into what kits are avalible or can be made. Sounds like the TRD kit will be the way to go if you have already had experience with it before.
    I went for the 3rd option to get away from the synco issues...Lol.
    I did see a second hand TRD gearkit on AE86.org, maybe worth a look there.
    Brad
  1. w57 close ratio gear box
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 28th August 2011, 10:09 PM
  2. Albins close-ratio T50 gearsets
    By Shifty in forum General Topics (No Technical Questions)
    Last Post: 22nd March 2011, 11:37 AM
  3. w 57 close ratio box
    Last Post: 18th February 2011, 04:08 PM
  4. WTB : AE86 T50 TRD Close ratio gearset
    By ae86hachiroku in forum Cars or Parts Wanted
    Last Post: 4th September 2009, 02:50 PM
  5. WTB close ratio T50 22 spline gearbox
    By charged in forum Cars or Parts Wanted
    Last Post: 31st May 2009, 11:48 AM
