Results 1 to 10 of 11
Thread: Suspension/Tire rwc question
    Mar 2011
    Killian
    Vic
    Preston
    Default Suspension/Tire rwc question
    Morning Folks, I have recently acquired my new ke70 and I am trying to obtain a rwc. I have a few questions, will I pass a rwc if I have cut springs ( once the lowest part of the car clears 100mm )?? Also I have 8inch wide wheels and looking to stretch 175 tires on, is there any law against stretched tires? I know I will have to roll my arches so that the wheel does not protrude past. Any help greatly appreciated. Car is located in Victoria. Thanks guys.
    Jake
    Northgate
    I have heard VIC is pretty strict on RWC now, most places probably won't rw cut springs and stretched tyres on wide wheels, yes there is a law against stretching tyres its the thing on the side of your 175 wide tyre that says std rim 5" or something not 8.
    Aug 2010
    Geoff
    mt dandenong
    yes to what jakel said. also guidelines say you cant increase width of rim by XX and im pretty sure 8" is alot wider then the stock ke70 rims.
    best to use stock stuff to get past roady then fit your stuff afterwards
    Mar 2011
    Killian
    Vic
    Preston
    Ok, thanks for that guys. Looks like I wont be making the all Japan day in 2 weeks
    Jake
    Northgate
    Just bring it std, probably more japanese than some of the cars that are full of chinese parts.
    Aug 2010
    Geoff
    mt dandenong
    Quote Originally Posted by gone0-60mph View Post
    can loan you some std springs and stock rwc rims to pass RWC.
    Mar 2011
    Killian
    Vic
    Preston
    Thanks very much for the kind offer. I already have all standard gear so may just chuck it back in and see how I go. Will let you know if I need anything. Thanks again.
    Veteran stahlz_ae86's Avatar
    Paul
    I'm only in Heidelberg area too so if you need any bits to borrow to clear you through shoot me a PM.
    Cheers,
    Paul.
    Mar 2011
    Killian
    Vic
    Preston
    Cheers for the offer mate. Might give you a shout if I need anything. You hardly have an arch roller I could get the lens of? Or know of anyone with one? Thanks again mate.
    Aug 2010
    Geoff
    mt dandenong
    bit of steel pipe works a treat, just go a little at a time
  1. [VIC]AE82 Twinky + hks cams/suspension/etc $2.2k Rego til June 2011 + RWC!
    By bryzilla in forum Cars for Sale (Toyota Only)
    Last Post: 28th August 2010, 07:53 PM
  2. Suspension Question
    By Skin in forum Technical - Questions
    Last Post: 1st January 2008, 06:25 PM
  3. Suspension Question
    By haydenzz in forum Technical - Questions
    Last Post: 8th September 2007, 06:43 PM
  4. front suspension question
    By driftster in forum Technical - Questions
    Last Post: 10th August 2007, 09:07 PM
  5. another suspension question
    By sprinters_r_mad in forum Technical - Questions
    Last Post: 1st March 2007, 06:46 PM
