Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 35
Thread: dash pads
    Aug 2010
    Geoff
    mt dandenong
    Default dash pads
    I think im onto a new way of re skinning dash pads. i've found a new type of thin vinyl that is really elastic that should be able to re skin a dash without the need for a vacuum vinyl machine like the dash doctor uses.
    benefits of this would be less cost to you and air vents/cluster surrounds would fit properly with the very thin material i plan to use.
    i'm going to try it out with a spare cracked dash pad i have laying around within the next couple of weeks. i'll take photo's of the step by step of prepping up the dash for covering so that if you guys want to do most of the prep the cost will come down more too.
    the vinyl only comes in matt black but that could most likely be sprayed to suit the color of your choice if needed.
    i'll keep you posted
    Steve
    Quote Originally Posted by dove grey 64 View Post
    Sounds interesting Geoff, im about to embark on a dash reskin, this is good timing.
    May 2010
    Tyrone
    Caulfield
    also interested. rough pricing?
    Also keen...
    Glenn ke_70's Avatar
    Clay
    Barossa!
    very interested.
    more interesed in the painting though.
    Aug 2010
    Geoff
    mt dandenong
    cant price it up until i work out how much material to use and time spent getting it right. and the material cost is just under $100 pr meter but also has to be shipped from europe.
    give me a couple of days.
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    Posting interest
    Pick up Sydney
    Pics can be sent by phone
    Emails ignored
    Texts ignored
    Private numbers ignored
    Wankers abused
    Senior Member Patric's Avatar
    Patric
    Enfield
    Keenk, please PM me when you have something going.
    Silver 86 Trueno Hatch.
    AE86 4age gear for sale - http://www.ae86drivingclub.com.au/fo...eats-Ae86-gear
    Side intrusion bars for your import - http://www.ae86drivingclub.com.au/fo...our-JDM-import
    Aug 2010
    Geoff
    mt dandenong
    apologies for the delay, got round to doing one today with results im not to happy with, still not too bad for a first go though.
    next one will turn out better, good thing is you can just rip off the vinyl and it takes away the contact adhesive .
    here is a step by step of dash prepping.
    first off this was the donor dash pad, came from a jdm halfcut and had some pretty bad cracks and indents. a hole was also drilled into it for a gauge or gps. some cool dealership stickers on the dash could not be saved.
    next step grab some 120 grit sand paper and a sanding block and knock back the edges of the cracks until its flat.
    then start filling in the cracks with bog, use a spring steel applicator when doing this as you can really press in the filler to the cracks and end up with a smoother surface, like bodywork the less you use the less you have to sand back.
    at this point if your doing this on the cheap you could just get a can of bumper black or anything else with texture and re spray your dash, especially if your cracks are thin you you needed minimal filler you could use some vinyl dye suff.
    mask up edges you dont want to spray over and wipe down with prepsol and a rag.
    this is where i stuffed up, i think i used too much contact adhesive and it left a lumpy texture under the vinyl under some spots.
    spray both surfaces with the adhesive.
    couldnt get pics on the part where i started to stretch/fit the vinyl but here is how it turned out
    not happy with this bit
    and this bit was the worst part, its going to be tricky trying to get this curve right, vinyl has to stretch heaps and then come back on itself.
    not sure if its going to be possible but i'll keep trying
    Aug 2010
    Geoff
    mt dandenong
    any feedback on the matte black colour? if nobody likes it then i wont bother using this stuff
  1. [SA] - KE70 Tacho dash & Uncracked brown dash pad
    By Seventy in forum Car Parts For Sale
    Last Post: 25th November 2011, 04:06 PM
  2. Dash pads & door seals
    By AIROCOBRA in forum Technical - Questions
    Last Post: 27th March 2010, 03:19 PM
  3. $300=Set of Challenger rims, clock dash, brake pads
    By AA902G in forum Car Parts For Sale
    Last Post: 15th February 2010, 05:09 PM
  4. $300=Set of Challenger rims, clock dash, brake pads
    By AA902G in forum Cars for Sale (Toyota Only)
    Last Post: 14th February 2010, 05:49 PM
  5. WTB RHD dash assembly package: dash, steering column etc.
    By Corollaman5 in forum Cars or Parts Wanted
    Last Post: 8th January 2009, 09:37 PM
