What ECU are you going to run?
hey guys, ive got a 4agze bare motor
and i just wanted to know what distributors i can use..
preferably electronic. it was given to me for my 86 project
and not much is known about it - no intake, dissy and different rocker
covers(so i cant really identify it)and are all 16 valve dissy mounting holes
the same? i know some run cas sensors
weber's ingenious design... twin 45s haha no ecu man running carbs
I dont know much about 4age with carbs but i seem to remember a modified 4k dizzy being used for the vacuum advance function.
Pretty sure the normal 4age dizzy cant be used or its difficult and not worth the effort too get working.
4age gear on 4k dissy
yeah thats what i heard too man, im just gonna have to trial and error different dissys and hope for the best.. dad reckons a later model 4age dissy should fit.
any 4age dissy will fit, but they are different internally, from CAS(cam angle sensor) i believe off GZE's(may be wrong) that run coilpacks, Bigport dissy 3 wire, and i believe smallport are 5 wire
4 wire, not 5!!!!
How are you going to get an advance curve out of it? Some msd 6al or something?
thank you
thanks for the info guys, helped me get an idea.. yeah the later gze ran a cas and coils i believe..
and not too worried about ignition timing at the moment but i have seen the msd timing computers working well with 4ages
so probably something along those lines.. or i could just lock it out lol
