Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: wanted ae101(silvertop) 02 sensor
    Member givemesideways's Avatar
    Nov 2012
    micheal
    nsw
    cameron park
    Default wanted ae101(silvertop) 02 sensor
    hello all
    just started on here the other day and already iv got the hubs and calipers iv been chasing for two months.
    I am hoping to have the same luck with this search. I really really REALLY need a silvertop 02 sensor. Before you say get a new one i know how much they are(360) off toyota and a months waiting to get it from japan(or so im told). i got one secondhand one from a wreckers but when installed the car still jumps into limp mode after what im guessing is a warming up period.
    any and now i mean ANY help would be FECKING brill
    thanks in advance mick
    Moderator Frak's Avatar
    Jamie
    No where near $360 I bought one new from Toyota just a short period ago for my AE111 and it was around $170.
    Hachiroku since 1994
    Mar 2012
    Brett
    Vic
    Morwell
    Im pretty sure you can use a o2 sensor off a various toyota models.
    As long as its a four wire o2 sensor. With a heater circuit?
    I cant remember what model toyota o2 sensor i used on my blk top.
    But i used an ntk o2 sensor. The part number is oza395- e9.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Just as an aside, an 02 sensor is not going to throw a silvertop computer into limp mode.
    It'll bring on a check engine light (sometimes) but not put it in a limp mode.
    There is probably something else wrong.
    It'll only bring a check engine light on when you bridge the terminals in the diag box... I ran a blacktop without one for months with no issues.
    What is your symptoms suggesting the car is in limp mode? Do a diag check also
    Nov 2012
    micheal
    nsw
    cameron park
    my symptoms are what i thought was limp mode. Eh well almost every time i start it up(not always because some times itll start fine and then once it warms up or so it seems it) it runs uneven, is dumping fuel like there is no tomorrow and when driven it has no power really and then (because i have no tacho yet) when it gets to about 3 or 4 k revs it backfires massive and wont rev any higher. the odd time it runs in what i call normal mode it idles perfect runs sweet and revs out to the limiter without hasitation.
    When i started doing this build i was not a member of dc and hadnt very much auto wiring experience even though im a sparky. i had a specilist come help me wire it from old diagrams and even though he was so maticulas be triple checking every wire both ends he had not much 20v experience.
    any ideas???
    the diag connection is still there but im not sure how much it is connected to sad face.
    Quote Originally Posted by Matt View Post
    Sep 2012
    Tristan
    Koongal
    i've used a aftermarket 02 sensor before (not on a 20v) sometimes they work well - you also have to make sure they got the same perimeters and crystal then just wire it in...cheaper option with a little morefuss
    but being through what i've been through i'd almost take the cover off your ecu and see if anything has happened inside, capacitors may have leaked out
    Nov 2012
    micheal
    nsw
    cameron park
    thanks twisty
    so what am i looking for when i take the cover ? iv had it off before but i wasnt really sure i was looking for. have you any pics at all they would help
    Quote Originally Posted by Twisty92 View Post
    Lawrence
    Wollongong
    https://www.google.com/search?q=leak...=lnms&tbm=isch
    First you need to work out your diagnosis plug and check what fault code you have if any.
    If you have a check engine light connected, you just need to bridge the TE1 and E1 pins in the diagnostic connector and it'll flash any current codes.
    Sep 2012
    Tristan
    Koongal
    This is what mined looked like inside but golberg has given many examples!
  1. 02 sensor issues =)
    Last Post: 13th February 2012, 04:11 PM
  2. Innovate Lc-1 Wideband 02 Sensor
    By Vaughn in forum General Topics (No Technical Questions)
    Last Post: 5th September 2011, 09:13 PM
  3. 02 sensor BP 4age
    By ozyvr4 in forum Technical - Questions
    Last Post: 28th April 2011, 11:06 PM
  4. 02 sensor Need help..
    By 17zon in forum Technical - Questions
    Last Post: 8th September 2009, 10:41 PM
  5. 02 exhaust sensor
    By HiLtOn in forum Cars or Parts Wanted
    Last Post: 17th April 2007, 09:45 PM
