Hey guys cant remember if a 4ag bolts to a t-18 crossmember?
no it doesnt, but i could possibly help you out with engine mounts
THE EVOROLLA
none of this SR shit . . . EVO 7 powered bitches
https://www.facebook.com/KeConversions
KE conversions - making your conversion simple
4AGE CA18 SR20 BEAMS 1UZ to KEXX mounting kits and hydraulic pedal box's available
I thought it would? Mounts look identical to ae71?
they come with T-engine mounts which are more like a K-engine than anything. As far I understand a complete ae71 or ae86 crossmember will bolt in. You can then either not use the rack and keep your steering box or alternativly convert it.
Then there's still the issue of going rack and pinion or keeping steering box.
thats not an issue haha...its a mandatory change!
Either way I wouldn't mind adding t18 to the list. If classic king isn't too far out of the way I could do the conversion for as little as $150 (block and rubber mounts)
It might be a long shot but my 4age to ta22 mounts may work?
THE EVOROLLA
should be identical
Actually I would probably give them a go yeah.
I am mates with Classis King and it's because we are putting my 4a gear into a series one. It already has rack and pinion steering. I'm pretty sure the guy we bought the car off said it has a ke70 crossmember. JORD0, tell me about these mounts and how much.
