Results 1 to 10 of 14
Thread: Lingering Revs
    Mar 2011
    Ced
    Rowville
    Default Lingering Revs
    Engine: Blacktop 20v
    Has anyone encountered 'lingering revs', where after you lift off the accelerator pedal, the engine's revs will hang there, or even increase a couple of 100?
    I tried playing around with the dashpot/throttle opener clearance. If set to spec, the revs hang up high, if disconnected completely, the revs hang down low. Quite annoying when changing gears, cause the revs are way too high for the next gear. Makes for easy downshifts though, I guess?
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    what car is it in, alot of new cars(manual) do this for emisions
    Prob your accelerator cable isn't closing the throttles properly / fully in that it is adjusted too tight.
    Mar 2011
    Ced
    Rowville
    It's in an ae86
    How much slack should you put on the throttle cable?
    I usually adjust it by having someone in the car, get them to hold it flat and ensure the throttles open fully, then when they let it go that they close fully.
    Then you nip it up, making sure it doesn't get any tighter.
    Too tight will see them stick open a little, and too loose will see the throttles not open fully.
    Mar 2011
    Ced
    Rowville
    I'll try it, thanks!
    Aug 2010
    Geoff
    mt dandenong
    tps? i mucked around with mine the other day and now i have the lingering revs that your talking about. did you knock your sensor recently?
    Mar 2011
    Ced
    Rowville
    No, havn't played with the tps. I'll recalibrate it to see if it's moved from spec.
    Veteran timbo's Avatar
    Tim?
    Wild West
    Do it via the 4AGE manual. It is time consuming and very fiddly!
    Mar 2011
    Ced
    Rowville
    Leaning towards it being the TPS. Throttle cable checked out fine, infact there was a little too much slack.
    I'm looking at the manual now, and the resistances are extremely varied. 0.3 - 6.3 kohms, so what should you be aiming for? 3.3 kohm?
  1. revs question
    By rich_86 in forum General Topics (No Technical Questions)
    Last Post: 31st December 2008, 05:35 PM
  2. project revs
    By exa6666 in forum Toyotas in the Media
    Last Post: 2nd March 2006, 12:15 AM
  3. Project REVS
    By jwvdg in forum Technical - Articles
    Last Post: 3rd November 2005, 05:16 PM
  4. Project revs update
    By drf72 in forum Technical - Questions
    Last Post: 1st November 2005, 02:39 PM
