Results 1 to 9 of 9
Thread: Blacktop starter motor on Westfield
    Junior Member Westie20v's Avatar
    Nov 2012
    Vince
    Western Australia
    Default Blacktop starter motor on Westfield
    Hello, new member, first post, hoping for some advice on sourcing parts and best option.
    I've recently acquired a Westfield with a 20v, which is an awesome combination. As the starter motor sits under the extractors however it suffers from heat and the solinoid sticks.
    Keen for some advice please on:
    - best starter motor option, replacement OE or aftermarket option
    - best value supplier/s
    - recommendations on needing to heat shield etc
    Thanks
    Westie20v
    Veteran timbo's Avatar
    Tim?
    Wild West
    Hopefully you have a ~1kW reduction starter or something that is worthwhile. It should have a heat shield between it and the exhaust manifold but obviously this is not enough. I doubled the stock heat shield with some ACL stuff and added a square on the block between the starter. I have found that over shielding is just as bad as none as you still want some airflow around it.
    Noooob
    If the solenoid is worn, they stick more so when hot than cold...
    A couple of options are to have it rebuilt , golberg offers a service on here to rebuild them, or you can also get a new 1kw one from him as well.
    Me personally, I'd ensure a relay is on the starter solenoid trigger wire ensuring the amperage given to the starter is as high as it can possibly be. Add the heat shield and if you are still having problems look into rebuilding your existing one.
    Nov 2012
    Vince
    Western Australia
    Thanks both
    Being a non-std install the heat shielding is not in place, and whilst there is ample air-flow with the exhaust exiting outside the car I'll fit heat shielding. It does stick when hot not cold also. A solenoid/starter rebuild also sounds the go, but clearly aftermarket high torque units sound like an overkill with these motors.....when not sticking it starts very quickly.
    Tim?
    Wild West
    You can get a new Denso 1kW reduction starter, like I have, from Auto Electrics Australia for $190. I'm not sure how much it costs to rebuild but with the state of my old starter I just didn't think it was worthwhile. As Matt said, a relay will do wonders with some proper heat shield.
    Nov 2012
    Vince
    Western Australia
    Perfect...why would I bother rebuilding....cheers
    Tim?
    Wild West
    My thoughts exactly haha. Throw up some pictures!
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Out of interest, is that a genuine Denso unit? Seems too cheap to be, especially if Auto Electrics Australia are selling them to the public for $190.
    As an aside, the most universal problem on the Denso gear reduction units is the solenoid contacts, these are relatively cheap to replace.
    I do a clean, regrease and contact replacement for $80. They are one of the few starters that are worth rebuilding these days because they're cheap to do so and you don't otherwise get lumped with a Taiwanese knock off that lasts as long as the warranty.
    Tim?
    Wild West
    Certainly is. I did talk and eventually buy it off a total Celica nut at AEA, so I'm not sure if that is a discounted price.
  1. SA: 4age 20v blacktop starter motor for sale
    By paulv in forum Car Parts For Sale
    Last Post: 13th February 2012, 12:45 PM
  2. Starter Motor
    By ae71neo in forum Cars or Parts Wanted
    Last Post: 2nd July 2008, 05:03 PM
  3. Starter motor I.D
    By haikii in forum Technical - Questions
    Last Post: 18th May 2008, 09:26 PM
  4. Starter motor
    By Beserker99 in forum Technical - Questions
    Last Post: 31st December 2005, 08:49 PM
