hey all,
yet again stumbled across another toyota part i've got no use for.
i've got a corolla radiator although not sure what it suits, might be an upgrade for the 4k with the right hoses and bracket to make it fit or even 4age with the right stuffing around and hoses.
no leaks on the radiator itself, although the drainage knob needs a new o-ring as water drops through the drain pipe, i've tapped it for a m6 bolt which when bolted up wont drop with no other leaks.
pics below as i'm unsure which corolla it came off
located VIC SE burbs
rarely on so txt me on 04138204 TWO ONE
