Results 1 to 10 of 12
Thread: silvertop igniter is it same as a black top
    Jul 2012
    jedd
    nsw
    ocean shores
    Default silvertop igniter is it same as a black top
    Yes they are both the same part number. The only way to tell what car the igniter came off is if it is still in the bracket.
    the silvertop has a starter relay on the bracket, where as the black top doesn't.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    tht's odd, I was told from a very reliable source that they are not and will misfire if swapped.
    Senior Member JinxD's Avatar
    Ash
    They share the same part number.
    However, a silvertop igniter will not run a blacktop. I found that out the hard way. The one that suits the blacktop has a green sticker and is common to a 1uz
    Same part number is same part... How would Toyota differentiate between orders?
    I've swapped them a few times without any issues
    Ash
    Your right, same part number.
    I've got two igniters with the same part number one came from a 20V silver top.
    One came from a 1UZ and has a green sticker. I just specified the part number and to suit a 1uz if you go to toyodiy.
    The same part number is listed for silvertop, blacktop 1uz and some 4runners. So theoretically they should be the same however like I said I've seen two variations and my blacktop would not run with the other variant
    And what i'm saying is i have had an ignitor off a silvertop engine run on a blacktop and a blacktop run with an ignitor with a silvertop many times... And additionally, if toyota have labelled them with the same part number and can not differentiate the difference between the part numbers how would you order one for a blacktop vs silvertop in the inventory system?
    By not run do you mean it wouldn't start at all? Did you earth the ignitor when you installed it? Maybe you had a faulty one, but at least 3 or 4x i've mixed the ignitors around without issues. A 16v ignitor will start the car, but won't run well.
    Ash
    Well as I said I ordered one to suit a 1uz which I knew would work. With the silvertop one the car would start and idle but wouldn't rev out. It would shoot flames and misfire.
    New from toyota?
    Jul 2012
    jedd
    nsw
    ocean shores
    Ok does one of you have aSpare one I could but ASAP ?? Please
  1. need a silver top igniter
    By ke2483 in forum Cars or Parts Wanted
    Last Post: 8th November 2012, 10:13 AM
  2. 20v silvertop igniter
    Last Post: 13th October 2012, 03:21 PM
  3. Replies: 2
    Last Post: 14th April 2011, 11:33 PM
  4. Black top VS Silvertop
    By damo46 in forum Technical - Questions
    Last Post: 9th July 2008, 09:53 PM
