Results 1 to 10 of 12
Thread: What size tyres and what guard work
    Senior Member TOFU's Avatar
    Terry
    Braybrook
    Default What size tyres and what guard work
    Hi guy
    have an 86 stock factory guards and camber to front, rolled guards on rear on stock shocks n spring.
    wheels are GTR superlite 15x10 -12.
    what size tyre should I be running to best suit my purpose min/no rubbing?
    if anyone has any photos of same fitment that be awesome. Thanks
    TOFUTERRY
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    You'll need a huge amount of work to the guards for a start if you have any hope of fitting 10's, tire size alone won't even get it close to fitting.
    Veteran Rice86's Avatar
    Richard
    Liverpool
    What is your purpose? hard parking? drifting? grip?
    Hard parking and drifting, 195/50 is fine, though x10 width will hit something at the front with stock suspension components at full lock if you can even get to full lock lol.
    With stock ride height you wont scrub your tyres when your car dips backwards or forward.
    below is my car on 15x8.5 -6 fronts and 15x9 -13 rears with 225/50/15 T1R tyres.. rear cars have been pull out as much as possible before the quarter panel started to flex and the front guards have been hand flared and pumped as much as possible.. i would say the front are about 30mm wider then stock and the rears would be about the same. STILL not enough clearance, they JUST scrub with these tyre size, they were fine with 195/50.. no scrub at all
    P.S i have adj LCA so i could dial a wider track up front then a normal AE86 so i wouldn't scrub anything when i had 195/50 tyres..now i have 225 so yes, a lot of fucking around just so tyres and wheels wont scrub..
    dose
    Richard
    Liverpool
    this would be a familiar car to a lot of us here, and i believe this car has the same wheels your referring to
    http://www.google.com/imgres?imgurl=...9QEwAg&dur=303
    dose
    Ridgehaven
    stock shocks n spring + 15x10 -12
    why?
    Terry
    Braybrook
    Stock because I need to go pass the pits to get it registered and wheels coz they where a babargain
    TOFUTERRY
    Richard
    Liverpool
    Lol.. Good enough reason, but prepare to fuck up your stock guards when you go lower
    dose
    Aug 2010
    Sutho Shire
    hammer and dolly for neat finish,i say 195 50 15 to give more clearance,if its a drifter who gives a fuck about max grip,225 on a 86 is a biggg tyre,not a big deal like made out to be,i would do other things first,thow my 9's -24's(14's) i got those under without a huge amount of work,goodluck,take your time doing it and youll be fine and runnin UGGEEEE WHEELS,might look to big without a body kit,overfenders or something thow,thats why i went back to
    8's -12 much better size on stock body 86
    Terry
    Braybrook
    Hahahhah I don't think ill do it with a pole and hammer maybe roller it with a gaurd roller.
    would you have a picture if your car ? Is 195 on 10" too stretch ?
    TOFUTERRY
    Richard
    Liverpool
    guard roller will only work on the rears, the front your going to need to use a hammer and dolly, you'll find out why if you try to use a roller on the front guards LOL..
    it depends what you want your tyres to do. 195/50 will fit, but you will get more tyre noise, less road comfort and obviously less grip..and to be honest it looks mexican with mega stretch tyres.
    if i could do it again, i would get wheels that is just enough to fit stock guards so there is no fucking around + getting defected for wheels to big
    dose
  1. Cheap second hand tyres!! Any size!!!
    By MattAE71 in forum Car Parts For Sale
    Last Post: 7th August 2010, 07:38 PM
  2. What size tyres to get?
    By -=GOODY=- in forum Technical - Questions
    Last Post: 26th October 2007, 11:11 AM
  3. What size tyres should i get?
    By oni in forum Technical - Questions
    Last Post: 3rd May 2006, 08:20 PM
