Results 1 to 6 of 6
Thread: Ae86 t50 reverse light plug
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    Default Ae86 t50 reverse light plug
    As title, after the loom plug that goes into the gearbox reverse switch
    sms me 0405549183
    Adam
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    You may not get any replies to this thread, because a T50 doesn't usually have a plug for the reverse light switch.
    It'll normally have 2 bullet connectors. If it doesn't suit that then somebody has been messing with the gearbox.
    May 2010
    Adam
    St George
    Ohh ok I bought one off these to put in and I just assumed it would have a plug to go on the end of it.
    All good if I can't find a plug ill just jam 2 bullet connectors in there
    Lawrence
    Wollongong
    TBH, I question if it'll actually work correctly. That type of switch you'll find on W-series gearboxes, so you can get a plug off something with a W box in it.
    But before you bother doing that, I'd check that you have continuity across the pins on the switch when you're in reverse and not when you aren't.
    I've seen too many cars with reverse light switches that are simply wrong and don't work. I generally find that 25% of Tridon cross referenced parts are just plain wrong.
    This is the OEM switch.
    May 2010
    Adam
    St George
    Thanks Mate, that makes perfect sence. I looked up the Tridon part number and that's what it gave me I'm yet to have a play and see if it works.
    If that fails do u know where I can get the correct switch? Or a Tridon part number
    Member _sawyer_'s Avatar
    Feb 2010
    Paul
    West melbourne
    and make sure the ballbearing is behind the swith to. had me scratching my head why it wasnt working
  1. T50 reverse light switch.
    By bradae85 in forum Technical - Questions
    Last Post: 27th August 2012, 09:30 PM
  2. WTB: T50 Reverse light switch
    By shawn_26 in forum Cars or Parts Wanted
    Last Post: 8th October 2009, 11:08 AM
  3. WTB: Light switch, dash light plug, roof clips
    By li21 in forum Cars or Parts Wanted
    Last Post: 18th May 2008, 10:08 PM
  4. T50 reverse light switch
    By ChrisGT in forum Cars or Parts Wanted
    Last Post: 23rd December 2007, 09:36 PM
  5. Reverse light switch from t50
    By slidn70 in forum Cars or Parts Wanted
    Last Post: 22nd August 2007, 06:39 PM
