Results 1 to 5 of 5
Thread: other makes parts that fit toyota
    Aug 2010
    Geoff
    mt dandenong
    Default other makes parts that fit toyota
    not sure if we have another thread for this but the other day i was looking for a tps at pick a part kilsyth and noticed that proton gti (mirage's i believe) and early hyundai and other early protons use the same tps as 4age toyotas, i took pics which i'll upload later. they use the clip type fitting for the 4 wires that are on the loom.
    pretty good if you need a replacement tps cheap.
    anyone else have some interchangable oddities?
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Same number on the TPS? Just because although they can externally identical, they can work in different orientations and have different internals.
    Daihatsu's share some parts with Toyotas (Toyota owns >50% of Daihatsu so no big surprise there).
    Mt Macedon
    Yeah, I think a Daihatsu Charmant motor looks like it might work in an AE86 too...
    There's a couple of huge threads on Toymods focused on this. One is "Toyota's interchangable oddities" for Toyota based stuff, the other I can't remember the name of, but is for other make stuff suitable for Toyotas. Hopefully a search will turn it up.
    Lawrence
    Wollongong
    Yeah, the Daihatsu Charmant (not sold in Australia) shares the same chassis and platform as an E7 Corolla, as such does the same as an 86.
    Best bet is Toyodiy. Find your part numbers then do a reverse lookup.
    Aug 2010
    Geoff
    mt dandenong
    Quote Originally Posted by Golberg View Post
    orientation is the same but there are no part numbers to match, the proton/hyundai ones have a black rubber type stuff on the outer casing like they are trying to hide another makes mark.
  1. Replies: 3
    Last Post: 21st June 2011, 08:52 PM
  2. Do AE86 seatrails fit into a Toyota T18?
    By TrdHowie in forum Technical - Questions
    Last Post: 6th March 2011, 01:35 PM
  3. what 13inch toyota rim will 240/570R13 slicks fit on?
    By matto1kute in forum Technical - Questions
    Last Post: 9th August 2010, 09:36 PM
  4. Replies: 1
    Last Post: 20th April 2007, 09:11 PM
