Results 1 to 7 of 7
Thread: tokico hts102r
    Veteran Rice86's Avatar
    Richard
    Liverpool
    Default tokico hts102r
    Hey guys
    have a pair of tokico hts102r sitting at home, they are the short stroke ones and adjustable from top..though not sure if they are good so question is..
    How do i know if they are blown? is there a way to test it? how should it re-act when compressed by hand? should it extend back on its own or what?
    Thanks in advance.. thinking about using them again if can sus out if blown or not.
    dose
    Moderator Sam-Q's Avatar
    Endeavour Hills
    ideally you would take it to a "shock dyno" where they chart the dampening characteristics. If you want to do it yourself putting dampers in is a pretty quick job, try it and see?
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    basic test, push down on shock shaft should be somewhat hard to do, and it should creep back up once you let it go
    Richard
    Liverpool
    i should mention its rear shocks only, yeah i just pushed down and its pretty hard, i checked and its set to max stiffnes, they dont extend back but i think thats how rear shocks are for the 86 since the diff will force the shocks to extended when installed on the car?
    i think they are still very usable, thanks guys
    dose
    Veteran Skylar's Avatar
    Ken
    Quote Originally Posted by lolwat View Post
    Only true of monotube dampers/"gas shocks". Twin tubes won't push back up. I don't remember what hts are but most likely twin tube.
    Michael
    Crimebrook 2749
    thank you
    Veteran timbo's Avatar
    Tim?
    Wild West
    Quote Originally Posted by Skylar View Post
    Correcto. I have HTS102F in the fronts, obviously, and that is what they do. The grub screw adjustment if awesome too.
  1. Replies: 12
    Last Post: 16th August 2010, 06:22 PM
  2. Tokico HTS102r 48way adjustable rear shocks
    By patience in forum Car Parts For Sale
    Last Post: 27th June 2010, 05:08 PM
  3. Tokico HTS102r adjustable rear shocks
    By duncan_86 in forum Car Parts For Sale
    Last Post: 13th November 2009, 04:08 PM
  4. Tokico HTS102r + other stuff
    By kaibeecee in forum Car Parts For Sale
    Last Post: 18th June 2009, 11:16 AM
  5. Tokico HTS102r rear shocks.
    By DRFTAE86 in forum Car Parts For Sale
    Last Post: 14th May 2008, 12:12 AM
