Results 1 to 4 of 4
Thread: Bell housing to fit 7afe
    Sep 2010
    dan
    vic
    Sunbury
    austraila
    Default Bell housing to fit 7afe
    Wat bell housing will fit a 7afe block. I'm getting w58gearbox to go behind the 7afe but I can get the bell housing modify just wanting to know Wat front half I'll need.
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    Whatever bell that fits a 4a fits a 7a. The bolt holes and dowels line up.
    However the extra braces that go from the bottom of the block to the bottom of the bell dont fit on the 7a block.
    So if you get a niteparts/dellow or that other cheap 4a to w5x conversion bell it will work.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    you're going to make a 7afe rear wheel drive? I would like to see that
    Sep 2010
    dan
    vic
    Sunbury
    austraila
    7age motor I'm building. Ok sweet cause if got a 4a bellhousing around to get a 4a to w5 bellhousing made up. Thanks jip86
