Results 1 to 10 of 14
Thread: Q: What is the Minimum length a tailshaft yoke, should sit on the gearbox spline?????
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Default Q: What is the Minimum length a tailshaft yoke, should sit on the gearbox spline?????
    Hey guys,
    I just want to hear other peoples thoughts on this question.
    What is the minimum length a tailshaft yoke should sit over the gearbox spline?
    Car: AE71 Wagon
    Engine and box - 4AGTE with W58
    I have just converted a AE71 wagon to a 4AGTE with a W58 gearbox.......
    Instead of getting a custom shaft made up (they cost $800 in Canberra), I wanted to use one of the huge pile of tailshafts I already have...
    I found one close to what I need, and got the Yoke changed to suit the W58 spline.....
    The yoke sits about 1.5 inches over the gearbox spline....
    I think it should be enough length, but there is a fair bit of the yoke exposed...
    It's always good to hear other people thoughts. Your opinion? Enough?
    JoJo
    Jake
    Northgate
    Is that as a single piece or two piece with center bearing? I'd say it would be plenty with a 2 piece.
    JoJo
    ACT
    Tuggeranong
    I am using single piece custom shaft from a modified KE20, with a W series yoke (RT104 Corona)
    Adan
    Oxley Park
    For some reason Im thinking the yoke needs to be at least half engaged on the spline. Im not sure where I heard it, but its the only thing that comes to mind.
    Otherwise, if you want to get another one made up, check my ebay link to GJ drivelines.
    Email him and he will give you a quote.
    I paid roughly 500 for my T50-r200 tailshaft, everything brand new. It only took 4 days from the quote to me receiving it too.
    http://www.ebay.com.au/itm/CUSTOM-3-...item27ae77798d
    JoJo
    ACT
    Tuggeranong
    Yeah. thanks Adan......
    At the moment, the yoke sits only about 1/3rd over the spline...
    I checked that link.... Still gonna be $700, not much differance from what we pay here, so I would rather spend that at a local shop if I was to get it made.... Thanks for the link tho
    Glenn ke_70's Avatar
    Clay
    Barossa!
    i just set mine up to sit halfway.
    as an alternative, you can get a spacer made up for the diff flange. much much cheaper
    dont get too conserned tho, you'll have a hard time trying to strip the spline out, they can take a massive shear force. shaft will break long before it.
    Paul
    JoJo was going to say that same thing about a spacer. Might have someone that can make it up for you if you need I will just have to get some measurements and material.
    Paul
    Adan
    Oxley Park
    You have to send him an email to get a proper quote. The price on his ebay ad is for a specific tailshaft.
    Otherwise yeah, a spacer would work fine. They use them in 4wds a bit, so if you get a decent one made up it would be sweet.
    JoJo
    ACT
    Tuggeranong
    Ok, Sounds good Paul......
    Mt Macedon
    I once screwed up the measurements for a tailshaft and ended up using a spacer on the diff flange to compensate. A couple of years later the tailshaft blew up on the dyno, most likely due to the spacer. I was lucky and it didn't do much damage, but I have also heard horror stories.
    Surely it can't be that expensive to get your current shaft lengthened (I paid $250 to get a shaft lengthened and balanced, and that is in Denmark where everything is insanely expensive)
  1. FS: T50 GEARBOX (22 spline) comes with tailshaft to suit
    By gmh6.0l in forum Car Parts For Sale
    Last Post: 9th November 2011, 06:40 AM
  2. WTB AE71 Tailshaft or yoke (sydney)
    By MoNsTaR in forum Cars or Parts Wanted
    Last Post: 18th September 2011, 06:25 PM
  3. t50, 22 spline tailshaft yoke.
    By awvg in forum Cars or Parts Wanted
    Last Post: 18th March 2010, 09:25 PM
  4. MZ20 tailshaft or yoke
    By hara_kiri in forum Cars or Parts Wanted
    Last Post: 31st May 2007, 01:43 PM
