Results 1 to 10 of 18
Thread: How wide til I need to bend inner guide
    Senior Member Gear-head's Avatar
    Jul 2010
    ViC
    A place near you
    Default How wide til I need to bend inner guide
    So I'm after a set of wheels but before I buy some really wide wheels I wanna know how wide can you go befor you wheels will rub the inner guide line ( metal behind the plastic ) I love my car and don't wanna bend/smash the metal body work and is there a way to get around the problem or can tell me the maximum size that I can run them
    Thanks
    Julian
    Northern suburbs
    depending on how low you go I guess.
    My 14x8 -14 needed the rear lips rolled flat so that they wouldn't rub on the tires enough though the tires were very stretched as well and slightly lowered. Front 14x7 -4 is still standard height and they only rub on full lock and that's on the plastic inner guard.
    what sort of wheels/sizes where you looking at getting ?
    Rust is a way of life
    Jul 2010
    ViC
    A place near you
    Maybe 14x8, 14x8.5, 15x8, 15x8.5 front 14x8.5 14x9, 15x8.5, 15x9 on the back
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Quote Originally Posted by Gear-head View Post
    Useless information without defining the recommended offset. Offset is the key as to how well your wheels will fit.
    15x8 -15 offset have lip protruding about 5 mm on the rear of an ae86 with 195 x 50. Slightly rubbing guards over larger bumps with 4.5kg rear springs and trd green shocks on number 5
    Veteran johl's Avatar
    Johl
    alot of 86's back in the day would run te37's and they were 14x7+/-0
    imo you could run 14 or 15 by 7,7.5,8 and maybe even 8.5 all with a zero a small negative offset and a 195/50/15 or similar 14 inch tyre.
    there is alot of info out there on what fits you will just need to google it.
    Veteran McLEVIN's Avatar
    Nov 2010
    ^^^What he said Post your suspension setup that will help more
    Jul 2010
    ViC
    A place near you
    Im in QLD for a holiday at this time wont be back till thursday for a pic to show you my suspension setup is died stock beside Jdm brakes and discs that I'll be fitting once I'm back
    I'll try to explan it's a little metal bit thats sticking out behind the plastic guard my front wheels keep nicking it when I do half turn the steering wheel I had a talk to a mate and he said I need a hammer and bend to fit wider wheels
    Nov 2010
    Veteran Rice86's Avatar
    Richard
    Liverpool
    I wouldnt go anything bigger then 15 in size and 8 in width with - 0 offset on stockish suspension on stock guards. Anything more "hecktick" will require guard modification, to how much depends on your wheels.
    dose
    Elite rthy's Avatar
    Leo
    Tulla
    ran XR4 15x7 +11 front and 15x7+3 rear w/ 195/50r15 and scrubbed with llovel superlow springs, front had around 10-15mm clearance from the tyre to the guard (which has the lip rolled).
    tried to run stiffer shocks/springs 8/6 and thicker swaybars but the car was way to stiff to maintain such height for daily driving
    also the front was hitting the side of the chassie rail and firewall on the front with stock lca/control arms
    if you plan on keeping stock height then you might as well run 35x11.5 15's muddies on black sunnies
  1. Tailem Bend Private day - 16th
    By obey wan boenny in forum Adelaide & SA Events and Discussion
    Last Post: 20th August 2011, 10:16 AM
  2. Tailem Bend Stadium Drift
    By JinxD in forum The Drift Channel
    Last Post: 16th September 2010, 08:46 PM
  3. SR20DET AE86 6000 reg til september
    By adam_loves_hachi_roku in forum Cars for Sale (Toyota Only)
    Last Post: 15th July 2010, 04:39 AM
  4. KE70 PARTING OUT TIL NO MORE INTEREST
    By Rich_86 in forum Cars for Sale (Toyota Only)
    Last Post: 9th June 2008, 07:17 PM
