Results 1 to 5 of 5
Thread: 12 pin ECU plug
    Adz
    Default 12 pin ECU plug
    Hi I'm chasing a 12 pin ECU plug from 4age smallport ecu. Other 12 pin ones should also fit.
    Veteran stahlz_ae86's Avatar
    Paul
    Yeah some others do fit, just be careful getting one though as there's 2 widths of 12 pin plug, I found that out the hard way.
    Adz
    Ah this is true ! it does have the wider terminals. cheers for that !
  • #4
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Did you get this, or still in need?
    I've got one if you still need it.
  • #5
    Adz
    Plug has been located, thank you very muchly for the offer
    A friend of mine just bought an ae93 with a conversion, plug wasn't being used ! *snip*
  • Similar Threads
    1. 4age 20v ST- Microtech ecu - wiring / plug pin outs
      By Twisty92 in forum Technical - Questions
      Last Post: 23rd October 2015, 08:16 AM
    2. Smallport ecu 12 pin plug
      By Fashionbmx in forum Cars or Parts Wanted
      Last Post: 30th December 2010, 10:19 PM
    3. WTB: 14 PIN Plug to suit 16v bigport ECU
      By DRFTAE86 in forum Cars or Parts Wanted
      Last Post: 16th March 2010, 08:13 AM
    4. Other cars with 14-pin ECU plug?
      By Killswitch in forum Technical - Questions
      Last Post: 29th December 2008, 09:17 PM
    5. 9 pin radio plug
      By vf24 in forum Technical - Questions
      Last Post: 28th April 2008, 10:30 PM
