i think the crank pully could be different i use a JDM 16v rwd pully on my bt20v and i had to trim some off the back of the shaft to make it line up with all my other rwd stuff i didnt expect that when i done my conversion at all
the dyno pull to 300rwkw
On the blacktop the cam belt drive pulley is wider to suit the timing belt which is also wider and has a different profile of teeth.
As for other differences what did you guys want to know?
