Use two nuts on the studs to get them out; thread the nuts on the stud then bind them on each other, you should then be able to pull the stud out by turning the nut closer to the head as it binds again the outer nut. I hope that makes sense...
Injector holes can be plugged up, how, I'm not sure. Someone will know though.
