Results 1 to 10 of 14
Thread: Genuine 4AGE high flow & strengthened oil pumps
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Default Genuine 4AGE high flow & strengthened oil pumps
    Genuine oil pumps with the upgraded wide gears featuring the round teeth.
    Also comes with base and pick-up gasket and the crank main seal.
    This can be readily fitted to the earlier 4age engines that have the prone to snap square teeth.
    Pic showing the size difference in width from another genuine type:
    This should be of particular importance to people running 7afe bottom ends as they likely recieved this type.
    These are guarenteed to be the best type available out of all the pumps.
    Price: $180 inc GST
    It is likely that I will also offer pumps that have been pre-ported for higher flow again for a small extra cost.
    Endeavour Hills
    Also of note there are pumps on ebay right now that are real cheap. One of the toymods guys bought one and it was crap in his eyes, so buyers beware!
    Feb 2012
    South Australia
    Mitchell park
    What sort of power/rpm can these handle??
    Endeavour Hills
    Quote Originally Posted by samboychips View Post
    Apparently they let go at about 9000 after a while, however I have have some TODA gears here soon, if you install them you can leave it much more
    Feb 2012
    South Australia
    Mitchell park
    Quote Originally Posted by Sam-Q View Post
    Awesome how far off are you from getting the toda gears? And could I have a price shipped to 5159? Cheers
    Endeavour Hills
    I am expecting them any day now. Postage for the gears alone is $8, for the pump together it's $13
    Feb 2012
    South Australia
    Mitchell park
    I'm presuming they fit all 4age? I have a smallport. If yes then I'm keen to take a pump off your hands
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    I have a 4GZE so assuming no issue to bolt up for me? shipping to sydney CBD?
    Endeavour Hills
    I have compared them to a 16V and I could see no differences. Technically there shouldn't be and only the blacktop should have something externally different. Just for the record I have used internally stock silvertop engines with the same type of pump but 15+ years old and rev them to my 8600 limit almost every time their driven. I have had two crank pulleys fail but nothing else.
    The pumps are $180 unmodified and $50 extra if their ported, the TODA gears also arrived today. To run the TODA gears you can get a second hand silvertop pump and put these in or buy one of mine and swap them. The TODA gears are not cheap.
    Endeavour Hills
    forgot to mention $13 for the pump sent to anywhere in AU or $8 for the gears alone
  1. Oil cooler kit + oil pumps + fuel rail + ae71 tach dash
    By Sam-Q in forum Car Parts For Sale
    Last Post: 26th July 2012, 11:31 PM
  2. quadlight wiring and oil cooler flow questions ke70, 4age
    By cooter in forum Technical - Questions
    Last Post: 1st April 2012, 12:32 PM
  3. high flow cat worth it?
    By Tim.duncan in forum Technical - Questions
    Last Post: 20th September 2011, 10:11 PM
  4. 4age oil pumps
    By cracker in forum Technical - Questions
    Last Post: 7th August 2010, 11:27 PM
