Results 1 to 10 of 13
Thread: Shithouse Handbrake
    Senior Member luke20's Avatar
    Oct 2012
    Luke
    Qld
    Brikdale/Redlands
    Default Shithouse Handbrake
    Hey guys. Just put in my T series diff into my ADM 86. and I noticed the handbrake is absolute poo. it barely slows the car down. Ive just put a brand new top cable on it and adjusted it at the shoes properly. It has 6month old drums and the shoes are fairly new too. My next step is pulling the handbrake cables off my old S series onto my T series. See if that helps.
    Anyone got any other ideas. I'd love to hook up a hydro, but the old thing letting me down is where to mount/hide it so the cops cant see it :/
    Mt Macedon
    Something's wrong. T series drums usually lock up well.
    In general, adjust the shoes nice and close to the drums, adjust cables so there is SFA lever movement in the cabin. It may help to give shoes and drums a good clean in brake cleaner, and sometimes it takes a little while for pads and shoes to bed in together (though it sounds like this shouldn't be an issue here).
    Also make sure you haven't adjusted the shoes too far out so they are rubbing constantly. Then they overheat and give you zero handbrake.
    Oct 2012
    Luke
    Qld
    Brikdale/Redlands
    Alright sweet as mate. Ill give it another look tomorrow arvo and see if I can fix it. Cheers for that
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    I have the same problem Luke.....
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    I had this problem and just put the s series handbrake cables on the t series fixed it. But you need to adjust them alot if you r using it for drift. If you use them just as a park brake one time adjusting should do the trick
    Oct 2012
    Luke
    Qld
    Brikdale/Redlands
    I'm using it for drift. I'm going to do exactly that. Put my S series cables onto my T series. Maybe that will work.
    Kaan
    Emerald
    It will but cables stretch and brakes wear so adjusting is needed regularly that's why a hydraulic handbrake is better, I just don't know how they go with drum brakes
    Mt Macedon
    S and T series drums have an automatic adjustment in them. This was often my problem on track. I think the adjusters move outward when using the brakes while reversing. Fine for daily use, but when you spin on track and step on the brakes hard they adjust too far, making the shoes rub, brakes overheat and you lose your handbrake. Also makes pulling the drums off a right pain in the arse.
    But when adjusted correctly I've found both S/T series drums to be very good at locking the rears.
    Oct 2012
    Luke
    Qld
    Brikdale/Redlands
    So I put my S-series Cables on. Handbrake feels great, until you start moving... It still doesnt lock up the rears at all. Even when I reef it with 2 hands. The shoes are adjusted pretty much perfect and the handbrake lever is also adjusted good. Only If there was a good spot to hide a Hydro Handbrake. haha
    Kaan
    Emerald
    Pretty sure it's legal to keep the mechanical handbrake and have a hydro handbrake too or engineerable
  1. hyrdo handbrake
    By sly1 in forum Car Parts For Sale
    Last Post: 20th January 2010, 11:12 PM
  2. handbrake Q's
    By rolla92 in forum Technical - Questions
    Last Post: 22nd June 2009, 05:30 PM
  3. hydroulic handbrake
    By albertos in forum Technical - Questions
    Last Post: 3rd June 2007, 01:43 AM
  4. Handbrake cable...
    By fat86 in forum Technical - Questions
    Last Post: 21st May 2007, 09:27 PM
