Results 1 to 4 of 4
Thread: Clear out, trd. Hks. Ajps. T3. T50 box Ae/ke parts nsw
    Member timpy's Avatar
    May 2010
    Tom
    Westleigh
    Default Clear out, trd. Hks. Ajps. T3. T50 box Ae/ke parts nsw
    To sell
    Good condition t50 box with adm bell housing with braided line from clutch master to slave ,clutch fork, ae86 gear box mount and gear box cross member, no shifter
    $650
    Trd 304* 8mm lift cams
    Intake and exhaust cams with dizzy gear on exhaust cam
    Suit standard bucket/shim
    Mint condition!
    $800
    Hks 304* intake 288* exhaust cams both with 8.35mm lift
    Dizzy gear on exhaust cam
    Mint condition!
    $800
    Brand new arp in the box
    -Fly wheel bolts
    -Rod bolts/nuts
    -Main studs/nuts
    -Head studs/nuts
    $500
    Ae/ke rear springs
    Near new ajps
    180mm free height 7kg
    $180
    Brand new ae86 kouki side parkers
    Got brand new, took one out of the packet droped it on the ground :/
    Chiped a tiny bit of plastic off the corner (wasnt happy) did not crack into the housing, will not let water into light. Other one is mint
    $150 for pair
    Jdm ae86 radiator
    Good condition
    Pressure tested, no leaks
    Has ae92 thermo fan attached
    $100
    Adm dash cluster
    200000km or something on it
    Very good condition
    Has fully sick white led bulbs
    $20
    16 valve 4age long motor
    Big port head
    Small port bottom end
    Was running,blow alittle bit of smoke
    Suits rebuild
    $250
    T3 gold 75mm trumpets to suit black top 20v throttles
    Mint condition near new
    Come with new stainless bolts
    $150
    St20v throttle bodys complete with injector and standard plate for 20v
    $200
    st20v throttle bodys just throttle bodys
    $180
    Contact tom on
    0408 588 687
    Located in pennant hills nsw
    Midnight Madness inc
    Sep 2009
    Rohan
    northshore
    to you wouldn't have a 20valve cam angle sensor lying around would you ?
    Veteran Bustin_86's Avatar
    Justin
    North-West Coast
    Pics of damaged Parker?
    Senior Member shammy's Avatar
    shamus
    vic
    albury/wodonga
    aus
    pics of 16v engine?
    and guessing smoke is piston rings?
  1. 4age cams, quads, arp hks trd t3
    By timpy in forum Car Parts For Sale
    Last Post: 7th January 2013, 09:21 PM
  2. NSW AE/KE Quarter Year Rendezvous
    By Rice86 in forum Sydney & NSW Events and Discussion
    Last Post: 28th November 2011, 11:58 AM
  3. 86 parts trd bride freedom hks recaro sparco uras j blood t50
    Last Post: 5th July 2011, 08:16 PM
  4. [NSW]Parts to clear
    By HiroshiFumi in forum Car Parts For Sale
    Last Post: 3rd June 2009, 08:19 PM
  5. FS: T18 Peddle box Suit manual conversion to KE/AE
    By Simon-KE70 in forum Car Parts For Sale
    Last Post: 3rd April 2009, 10:50 PM
