Results 1 to 10 of 12
Thread: Camshaft bearing cap bolts
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    Default Camshaft bearing cap bolts
    Hi there peeps,
    I may have a really stupid question, or it may be not so stupid.
    Now one of my camshaft bearing cap bolts have snapped off!! Now I can hopefully get it out usuing a ezy out that's not a problem, question is what bolt to I replace it with..?
    can I just use a grade 8.8 high tensile bolt the same size or do the have to be a special type?
    i know it may sound silly but my brain is farting ATM.
    Thoughts ? :/
    Veteran timbo's Avatar
    Tim?
    Wild West
    Find one from someone who has spares! I think the factory torque spec is around 13Nm. What about Coventry or something along those lines?
    Alex
    Wagga Wagga
    I'm sure you could get away with a different high tensile bolt, but I think the best option would be to get a new genuine replacement from Toyota. It is going to be only a tiny cost of what may be a much larger cost in the long run if something did go wrong. Peace of mind
    Alex's 4AGTE KE70
    Or so was thought...
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    i has lots of them, if you really get stuck
    It should come out easily....
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Be prepared if it's the bolt that I am thinking it is then their an M7, your not likely to get too far trying to source one of these from a conventional bolt store.
    West
    I just threw away a full set of 4age cam caps and bolts.
    May 2010
    Adam
    St George
    Cheers for the replies.. lolwat, I will hit u up for some if u don't mind. Just sent u a msg.
    Mt Macedon
    Sam I'm 80% that 16Vs are M6 and only 20Vs are M7.
    Those bolts also have a tendency to break before their rated torque. And while the right bolt is always nice, it's not highly stressed, so anything that fits will do.
    May 2010
    Adam
    St George
    I can confirm my 16v head uses m6x1
  1. Cam Cap Bolts!
    By Robo86 in forum Technical - Questions
    Last Post: 8th September 2009, 12:41 PM
  2. URGENTLY NEEDED - Thrust Bearing Carrier ae71 + bearing
    By ethsar46 in forum Cars or Parts Wanted
    Last Post: 18th March 2009, 04:03 PM
  3. front wheel bearing cap
    By fuzzy in forum Technical - Questions
    Last Post: 18th September 2008, 12:09 AM
  4. camshaft bearing cap nuts
    By DriftPlease in forum Technical - Questions
    Last Post: 18th April 2008, 07:57 PM
  5. bigport pistons and camshaft bolts
    By fozz in forum Cars or Parts Wanted
    Last Post: 20th February 2008, 12:23 AM
