Results 1 to 8 of 8
Thread: Toyota Engine Compression ratios - How they come from factory
    Default Toyota Engine Compression ratios - How they come from factory
    Standard Factory Compression Ratios
    4age
    16v Bigport - 9.4:1
    16v Small Port - 10.3:1
    20v Silvertop - 10.5:1
    20v Blacktop - 11:1
    Gze
    Supercharged GZE Bigport - 8:1
    Supercharged GZE Smallport - 8.9:1
    7a
    7afe - 9.5:1
    Aug 2010
    Geoff
    mt dandenong
    was trying to work out what 9.4:1 would convert to in psi readings and found this on google
    There is really no 100% accurate way to calculate your compression ratio from psi, but there is a formula that will get you fairly close. First take your psi reading and divide it by 14.7 (for example, psi reading is 170 divided by 14.7 = 11.56). Then take your engine size and multiply by .01 (for example 250cc x .01 = 2.5). Then add 1 to that number, so then you have 3.5. Last you will take the 11.56 that you got from dividing the psi reading (170psi) by 14.7 and subtract that 3.5 from the 11.56 ( so you have 11.56 - 3.5 = 8.06). And that is your approximate compression ratio (8.06:1). Like I said, there is no formula that will get you an exact reading just because it is virtually impossible, but that formula always gets you fairly close.
    now im picking up my brain off the floor.
    im pretty sure it works out to between 170psi to 199psi, anyone else know?
    The actual numbers on the compression test can be influenced by a heap of different things... I've generally learnt that the variance between cyclinders must not be more than a few % otherwise you have a problem.
    Leak down tests are also good, but not fool proof. You can tell allot by using a bore scope if you know what you are looking for.
    Glenn ke_70's Avatar
    Clay
    Barossa!
    we adding to these?
    yeah why not....
    Senior Member Skid_KE70's Avatar
    Daimon
    Tasmania
    Launceston
    it would be interesting to see what compression ratio a silvertop 20v 4age is with smallport 4agze pistons. this seems to be a fairly common conversions for people wanting to go turbo with a low budget. i for one have used this combination and it worked well aside from it then being an "interferance engine"
    ---- Fryin Fifth Represent ----
    I saw a comp test result on a 14:1 engine over the weekend and the result was up around 255psi per pot....
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    my old bigport had 235psi across all 4, bigport pistons, head was shaved nothing extreme, TRD 0.8 headgasket
    cam overlap isnt going to help when getting comp readings either
    useing that "formula"from above, it ahs 10.98:1, beleivable, when it says multiply your engine size by 0.01, per cyc not over all
  1. 7AG and compression ratios
    By Golden Circle in forum Technical - Questions
    Last Post: 28th May 2012, 06:36 PM
  2. Working Out Compression Ratios
    By JJRC in forum Technical - Questions
    Last Post: 17th November 2011, 06:22 PM
  3. compression ratios with shaved head
    By dr1ft-pig in forum Technical - Questions
    Last Post: 22nd October 2007, 07:42 PM
  4. Compression ratios
    By Jazz9 in forum Technical - Questions
    Last Post: 17th September 2007, 01:43 AM
