Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 32
Thread: '''''Wilwood big brake kits for popular makes and models'''''!!!
    Gone
    Joel
    Picton
    Default '''''Wilwood big brake kits for popular makes and models'''''!!!
    We are proud to announce the supply of wilwood big brake kits for popular models.
    Toyota, Nissan, Honda, Mazda, Mitsubishi, Subaru, Lexus, Chevrolet and even BMW
    All kits include:
    2 x Calipers (as specified)
    2 x Rotors (as specified)
    1 x set pads / caliper (Wilwood bp10)
    2 x calliper adapter brackets
    Braided stainless steel brake lines
    grade 8.8 mounting hardware
    Please read the underlined notes:
    - All kits are a complete bolt on package.
    - All kits unless specified use Wilwood Dynapro calipers.
    - All kits come with Wilwood 2 piece rotors.
    - All Kits come with plain rotors unless specified.
    - Upgrade to slotted rotors for - $139/kit
    - All callipers do NOT have dust seals.
    - Dust seals can be added to the callipers when you order for $65 (cost is per kit, eg. 2 callipers)
    We will be offering an ae86 complete front and rear big brake kit!
    6 piston front - 298mm or,
    4 piston front - 280mm
    4 piston 254mm kit that fits some 13" wheels! (Front only, some wheels may require spacing)
    4 piston rears with cable handbrake function - 280mm ( Powerlite rally calliper, standard cable needs to be modified )
    Some kits are available with brembo or AP racing callipers. (POA)
    All kits are specified for RACE USE ONLY.
    Toyota: AE86
    Front brake kits:
    Ae86 - 4 piston 254mm kit, $1250
    AE86 - 4 piston 280mm kit, $1250
    AE86 - 6 piston 296mm kits, $1650
    Rear Brake kits:
    AE86 - 4 piston 280mm kit, $1195 (powerlite caliper pictured below)
    Nissan: S13/14/15
    please specify 4 or 5 stud hubs.
    Front Brake kits:
    S13 - 4 piston 327mm kits, $1395 (slotted Rotors standard)
    S13 - 6 piston 327mm kits, $1695
    Rear Brake kits:
    S13 - 4 piston 300mm kits, $1550 (powerlite caliper pictured below)
    Dynapro 4 piston W/O Dust boot
    Dynapro 4 piston With Dust boot
    Dynapro 6 piston
    Powerlite Rally (ae86/S13 Rear)
    Not the actual kit, image is of calliper and how cable mech works
    Contact me with any questions or specifications you may have.
    Joel
    Member erik's Avatar
    Feb 2011
    Erik
    Southcoast
    whats the smallest size wheel you can run with these kits?
    Gone
    Joel
    Picton
    As above , 13" wheels with the 254 mm kit.
    Some 14" wheels do fit the 280mm kit and some require spacing.
    15" wheels are fine and need no spacing etc.
    Gunner
    Thats awesome, good work joel.
    Feb 2011
    Erik
    Southcoast
    I'm a hoarder of 13"s, so im mostly into the 254mm.
    I'm looking forward to this
    Jake
    Northgate
    DAMN! I sold my 13's so I fit the t3 wilwoods, haha.
    Glenn ke_70's Avatar
    Clay
    Barossa!
    so you go directly through wilwwod now or still through t3?
    Member 4ag te72's Avatar
    Jan 2011
    Daniel
    Elizabeth
    What would pricing be for a 280mm kit for a ke70?
    Gone
    Joel
    Picton
    Quote Originally Posted by ke_70 View Post
    No not through T3, Wilwood.
    Quote Originally Posted by 4ag te72 View Post
    Still waiting for the freight costs so I can work pricing out.
    Though there won't be a ke70 specific kit, you will need Ae86 struts.
    I will post an application list once everything is finalized
    Gone
    Joel
    Picton
    still got a heap of stuff to do, all enquiries welcome
  1. Wilwood T3 AE86 Big Brake Kit
    By sundee in forum Spirited Drive
    Last Post: 11th November 2012, 10:41 AM
  2. Wilwood big brake kit clearance
    By DR86FT in forum Technical - Questions
    Last Post: 7th November 2012, 11:41 PM
  3. Wilwood brake kits
    By Fuzzy in forum Technical - Questions
    Last Post: 7th December 2010, 09:02 AM
  4. FS: [SYD] Wilwood/T3 big brake kit (brand new)
    By willio in forum Car Parts For Sale
    Last Post: 11th May 2010, 06:33 PM
  5. WILWOOD Brake kit
    By myt-16v in forum Technical - Questions
    Last Post: 1st November 2007, 12:11 PM
