Results 1 to 4 of 4
Thread: brake shim?
    Mar 2010
    Jason
    West Brisbane
    Default brake shim?
    Its a newb stupid question but I have to ask. I lost one of the shims for my front brake pads. I bought new pads for adm ae86 calipers (DB398). New pads have some sort of rubber or viynal backing on them, say the thickness of black gaffa tape. Im thinking this is the equivalent of a shim? The 1 shim I have here is less then a 1mm thick anyway. The back of the old pads are just a flat metal surface. Just want to know if I can do away with using shims.
    Senior Member mcBen's Avatar
    Mar 2012
    Eastern burbs
    shims are just for reducing brake noise, you can do without them but the brakes might squeel a bit. Buy some brake quiet from Repco for $5
    Mar 2010
    Jason
    West Brisbane
    Cheers Ben, will head to repco tomorrow.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    never used "brake quiet" not a big fan myself, running them with out the shims will be fine, you will find after some heavy braking that layer on the pads(like gaffa tape) will be cut out from the piston
  1. Bendix “Advanced Blue Titanium Stripe” Brake Pads and Shim Technology
    Last Post: 8th January 2013, 04:39 PM
  2. Valve Shim tool 4age + micrometer, borrow or buy.
    By FORDISGAY in forum Brisbane & QLD Events and Discussion
    Last Post: 15th April 2012, 02:31 PM
  3. 3sgeor 4age shim under bucket lifters
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 2nd September 2011, 10:15 AM
  4. Valve shim clearances.
    By ae86 slide in forum Technical - Questions
    Last Post: 19th May 2010, 11:16 PM
  5. How to shim a zenki factory oem (spring) lsd
    By hachi_dk in forum Technical - Questions
    Last Post: 25th December 2009, 08:07 PM
