Results 1 to 5 of 5
Thread: Daewoo lanos coil wiring
    Senior Member davidgarratt's Avatar
    david
    morayfield
    Default Daewoo lanos coil wiring
    Hay as the title states I'm chasing the wiring pin out of the 4pin Daewoo lanos coil. Any help would be great
    david
    morayfield
    OK this is a pic of the plug as far as I can tell there will be 12v /trigger / negative / tacho. Looks like red is 12v and black is negative but I don't know about the others :confused:
    david
    morayfield
    Ok worked it out for all those playing at home. The pink wire is batt + and the black wire is batt - and the orange and white are trigger for the coils
    Thanks for the update... What are you using these on?
    david
    morayfield
    Matt I'm using them on a bigport 4age running a Razorback ecu because my igniter shat itself so on this went lol.
  1. Clean Daewoo Lanos
    By Shitbox in forum Cars for Sale (Not Toyotas)
    Last Post: 20th May 2010, 11:59 PM
  2. 4ac dizzy/coil wiring help
    By rthy in forum Technical - Questions
    Last Post: 6th February 2010, 12:33 AM
  3. Wiring help - Coil +12v
    By Chrisso in forum Technical - Questions
    Last Post: 26th September 2009, 07:22 PM
  4. 4ac ignition coil wiring
    By biGtai in forum Technical - Questions
    Last Post: 16th April 2009, 12:57 AM
  5. 4kc Coil wiring
    By sonsta in forum Technical - Questions
    Last Post: 9th March 2009, 04:41 PM
