1992 toyota cressida grande genuine 203,000kms
-1JZ-GTE
-600x300x76 black HYBRID fmic with black custom intercooler piping
-2.5" custom mandrel bent catback exhaust/ high flow cat has stock 1JZ dump pipes
-H4 phillips crystal vision 4300k
-2JZ PCV grommet & 2JZ twin turbo PCV valve
-prosport boost gauge
-walbro 255lph fuel pump
-stock twin turbos in good condition with factory wastegate ported 3mm larger
-tinted sunroof
-sony mp3/aux headunit/ 6.5" fusion speakers at the front/ 6x9 JBL speakers at the rear
-front & rear fuji heavy duty brake pads
-heavy duty automatic gearbox with a shift kit
-6 custom high pressure power steering hoses & adapter from steering rack to pump
-custom accelerator cable made up
-alloy radiator
-drift boost controller
-hks fuel cut defender
-10 pounds at 180kw at the wheels
Now running 16.5 around 210 220kw
no accident history paint is very good leather has few crack And rip on drivers seat nothing mmajor everything electric wworks air con does work the pipes are jut not bolted on I never got around to it
will swap for ae86 na or turbo'd anything else must be na as I'm on my p's
or 7500
located south coast nsw
april rego
0421190892
pics here or can sms
http://www.ae86drivingclub.com.au/fo...jamies-1j-mx83
