Results 1 to 7 of 7
Thread: clutch slave cyl feed in the way of manifold down pipe
    May 2010
    Randwick
    Default clutch slave cyl feed in the way of manifold down pipe
    Hey lads, today I was fitting a new janspeed system to the 86, when installing the 4 branch manifold the downpipe is clashing with the fees pipe for the clutch slave cylinder (right where the male threaded fitting treads into the slave cylinder) I'm thinking I'd I get a hose with a 90 degree bend it should solve the problem, has anyone encountered this problem before?
    Senior Member toyotakraze's Avatar
    Jun 2009
    Robbie
    Coorparoo
    Quote Originally Posted by jmae86 View Post
    Sam Q is your man
    Who took the jam outta your doughnut?
    You took the fucking jam outta my doughnut, Tommy. You did.
    Yeah grab a flexible hose and run it from the master to the slave...
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by Matt View Post
    Well not the whole way...
    I would gently massage the hardline to a better location, and then run a braided line over a more appropriate route. Move the mount if you're handy with a welder. A slightly longer than standard braided line may be required to achieve good clearance and safe routing.
    As an overall solution, this is why some people choose to convert to a JDM clutch hydraulic arrangement, as they have the slave cylinder on the drivers side to keep it away from the 4AGE exhaust.
    Rob
    Moorabbin
    Get a slightly longer flexible line with a banjo fitting for the slave.
    Rubber will be fine, don't need braided for the clutch hose.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    750mm braided line with 45 degree banjo one end(master) and a straight banjo the other(slave)
    May 2010
    Randwick
    thanks for the replies lads hopefully the banjo fittings should do the job,didnt get time to call to any hydrolic hose shop today,will get it monday
  1. 1jz injectors, slave cyl, clutch
    By Brendo in forum Car Parts For Sale
    Last Post: 1st November 2011, 12:48 PM
  2. AE71 clutch hard line and slave cyl
    By J0RD0 in forum Car Parts For Sale
    Last Post: 3rd July 2010, 09:30 AM
  3. speedo cable, brake mater cyl, clutch master cyl
    By dr1ft-pig in forum Car Parts For Sale
    Last Post: 9th June 2008, 12:24 PM
  4. JDM T50 / TA22 Slave Cyl Problem
    By Andor in forum Technical - Questions
    Last Post: 15th July 2007, 12:59 PM
  5. T50 Cltuch Slave Cyl hose
    By marvis in forum Technical - Questions
    Last Post: 9th April 2006, 07:33 PM
