Results 1 to 3 of 3
Thread: [BNE] front coilover setup for ke/86/corona/mx73 and 22re dual carb setup (EOI)
    Feb 2012
    Christian
    Bunya
    Default [BNE] front coilover setup for ke/86/corona/mx73 and 22re dual carb setup (EOI)
    hi all...
    have some parts for sale from my rt142 corona...
    i have a front pair of weld in coilovers that consists of mx73 8kg weld in kit and also mx73 hubs & brakes, (vented and bigger calipers) that can come with rt142 power steering arms, which are apparently the same length as ra65/sa63 p/s arms obviously just different bolt spacing (87mm instead of 85mm that's used in ke/86) if you wish to use these on ke or 86 you will need the power steering arms and put them onto your lca's.. they also have 86 camber tops.. inserts are believed to be axg's.. however one dampener adjuster has broken so you cant adjust it ... and in all seriousness passenger side insert is quite rugged and has very little rebound... although new insert kits are $200ish even though these are still useable...
    im looking for $350 ish for this setup..
    it goes crazy low.
    another item... side draft dual carby setup which i think of it as itb's for a 22re. these have come from america but originally japanese built... had 20v trumpets on it but sold separately. please inbox or preferably text 0439326459 to offer but please do not low ball me i know the rarity and know what i paid for them... stupid offers wont be replied to... thanks.
    look identical to this...
    Ridgehaven
    Quote Originally Posted by getlow View Post
    rt142 power steering arms, which are apparently the same length as 86 p/s arms
    RT142 PS knuckle is quite a bit longer than AE86 PS knuckle
    Feb 2012
    Christian
    Bunya
    Quote Originally Posted by benzo View Post
    sorry ill edit it out... thanks
  1. T3 coilover front set up with trd blues and rear setup
    By 70rolla in forum Car Parts For Sale
    Last Post: 26th September 2011, 11:49 AM
  2. WTB: 40-45mm dual carb setup
    By Jimmee1990 in forum Cars or Parts Wanted
    Last Post: 13th August 2011, 02:37 PM
  3. WTB - 4ac twin SU vacuum carb setup dual throat
    By JDMBenji in forum Cars or Parts Wanted
    Last Post: 3rd June 2010, 03:55 PM
  4. Coilover front and rear suspension setup
    By *Hashiriya* in forum Car Parts For Sale
    Last Post: 23rd September 2008, 04:17 AM
  5. EOI: Coilover Suspension Setup
    By thanhngo in forum Car Parts For Sale
    Last Post: 25th May 2007, 03:16 PM
