Results 1 to 5 of 5
Thread: ae86 4ac electronic ignition
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    Default ae86 4ac electronic ignition
    anyone else put an electronic dizzy in a 4ac and have the tacho stop working?
    dont think it would need a tacho booster. also when u connect the tacho wire to the neg terminal of the coil it doesnt want to start untill you stop cranking.
    just thought id ask here before i went outside in the heat lol
    cheers Kaan
    Aug 2010
    Geoff
    mt dandenong
    Nope, I put a electronic dizzy in my 4ac and didn't have that issue, search on google for fitting elec dizzy to 4ac and on one of the forums someone made a clear diagram even I could work out so follow that and you'll be right
    Aug 2010
    Geoff
    mt dandenong
    Also you'll need the coil that came from the ae 82 or similar, don't think you can use the 4ac coil
    Mt Macedon
    Sounds like you may have connected something wrong. The stock ballast resistor is bypassed when cranking, so maybe something funny there is causing your no start during cranking.
    Kaan
    Emerald
    I'm using the coil off the ae82 , ign to +
    And trigger off the electronic dizzy to - and ign to the ign module . Ill have a play later with it.
  1. electronic ignition
    By willa in forum General Topics (No Technical Questions)
    Last Post: 5th September 2009, 02:55 PM
  2. 4ac electronic distributor
    By shakes in forum Technical - Questions
    Last Post: 22nd June 2009, 01:17 PM
  3. WTB Crane Cams XR3000 Electronic Ignition Unit
    By ol_skl_jp in forum Cars or Parts Wanted
    Last Post: 15th July 2008, 05:14 PM
  4. 4ac electronic dizzy
    Last Post: 19th March 2008, 07:56 PM
  5. 4ac Electronic distributer.
    By superbmobile in forum Technical - Questions
    Last Post: 4th August 2007, 10:32 PM
