View Poll Results: Should I keep the AE71 slant front, or go JDM quad lights?
Voters
11. You may not vote on this poll
  • AE71 slant front
    5 45.45%
  • JDM Quads
    6 54.55%
Results 1 to 10 of 51
Thread: The Green Machine - AE71 4AGTE Pano Build
    Mar 2011
    Ali
    Default The Green Machine - AE71 BT20V Pano Build
    Finally getting around to do this.
    4AGTE is not going ahead.
    Motor will be Blacktop 20V.
    BODY/EXTERIOR:
    2pak hot house green with gold sparkle.
    Has small rust bubbles coming up in the bottom of the tailgate that needs attention.
    Has a 50c bit of cancer in a front passenger rail where the factory shipping/tow point, small pin dents in passenger 1/4 and front guard, scratch mark in paint on bonnet.... Good base...Have no idea how many Km's its done
    Upside down Toyota Badge on grille
    Staying pointy nose
ID:	37102Click image for larger version.
    INTERIOR:
    Has had 5 seat conversion done with mod plate.
    Driver Recaro LS fishnet head rest seat.
    Has KE70 Non Tacho Dash installed with full KE70 donor wiring loom (cabin and engine bay)
    Battery re-located rear
    ENGINE:
    Blacktop 4A-GE 20V
    SQ rwd conversion parts
    SQ 50mm billet stacks with ITG Twin DCOE Foam Filters with mesh inserts (don't suck in)
    SQ COP conversion Yaris coils
    Microtech LT10S with hand controller
    Stock injectors
    Ebay AE71 alloy 3 row radiator
    Attachment 38156
    FUEL SYSTEM:
    Has modified stock AE71 Pano tank - Has sump / surge tank welded into the bottom of it with 10an fitting, steps down to 8an to aeroflow 30micron pre pump filter, to Walbro 155LPH (supports up to 400hp) with 8an fittings up to 10micron post pump filter in engine bay, to factory 4age blacktop fuel rail,
    All hose is stainless braided 8an.
    All fittings and filters are stealth black finish.
    DRIVELINE:
    W55? - Was sold to me as W57, but isn't, ratio's are wrong for W57.
    Niteparts W series bellhousing
    Niteparts 1GFE starter motor conversion
    NPC ceramic 5 puk sprung centre clutch with custom beefed up Pressure plate
    Driveline services Custom Tailshaft rated to 300hp
    Stock Diff S series with factory pano 3.5:1 ratio
Name:	Nicks Clutch's.jpg
ID:	37604Click image for larger version.
ID:	37106 Click image for larger version.
    BRAKES:
    MA61 Hubs and Vented Disc's (fits larger XT130 stub axle)
    MX62 Calipers with custom machining on XT130 Strut/Caliper mount to make it works!
    Standard rear drums
    SUSPENSION:
    XT130 Struts with Otomoto weld on coilover sleve kit
    8kg springs
    Front Gaz adjustable shock absorbers
    Cusco? blue adjustable camber tops
    Billet Techno Toy Tuning PS knuckles
    XT130 Lower Control Arms with brand new Ball joints
    AJPS Motorsport Adjustable tie rod ends
    Stock rear leave's with blocks
    WHEELS:
    Work Equip 01's 14x7j with185 60 14's
    Veteran haveaparty's Avatar
    Mar 2010
    Brett
    Crestmead
    Nice rig mate. Just an FYI. Rn25 hilux diff bolts in. Diff mounts over hang the leafs about 5mm on each side but shouldn't be a drama. I'm fitting one into my pano now. Just need bigger u bolts and no doubt need to drill a hole in the bottom plate a bit bigger.
    Mar 2011
    Ali
    Legend!
    Are RN25 rare?
  • #4
    hot wagon man...
  • #5
    Jon
    Durack
    I know the person that used to own this. Should be a good base
  • #6
    Mar 2011
    Ali
    Is he on these forums?
    Its been raped, as in I have to rewire the entire car from scratch.
    Has KE70 engine X memeber, dash is busted up.
    Interior will have to be redone also.
    But yeah, your right, its a good base.
  • #7
    Mar 2010
    Brett
    Crestmead
    Yeah pretty rare as far as I know. And expensive if the person selling knows what's he got. I was lucky with mine. Swapped my set of superlites for mine off of a mate.
  • #8
    Mar 2011
    Ali
    Quote Originally Posted by Low Style View Post
    Do you know of any vids or pics of it in is day?
  • #9
    Jon
    Durack
    last person i knew driving it was a chick back in the old boostcruising days. Was in ok condition then - must of changed owners a few times since
  • #10
    Mar 2010
    Brett
    Crestmead
    Was this 20v turbo by any chance once??
  • Page 1 of 6 1 2 3 4 5 6 LastLast
    1. The Green Machine does it, but did he really?
      By Gunner in forum Offtopic Discussions
      Last Post: 6th December 2009, 06:31 PM
    2. THE MEAN GREEN FAST EDDIE MACHINE
      By orangechargd86 in forum Cars for Sale (Toyota Only)
      Last Post: 4th August 2008, 11:47 AM
    3. WTB Green machine wheels
      By jordinary in forum Cars or Parts Wanted
      Last Post: 17th February 2008, 10:34 AM
    4. Jono's Green Machine
      By poh_86 in forum AE86 Owners Forums
      Last Post: 12th January 2006, 04:00 PM
