Results 1 to 10 of 10
Thread: Wanted: Toyota E Series (E292) rear end out of a YR20 Tarago
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    Default Wanted: Toyota E Series (E292) rear end out of a YR20 Tarago
    Hey guys, I'm trying to find something for the SR conversion. I know you can go Hilux and F series, I've been through all that but I don't want an LSD and I don't want to cut down Axles as I basically cannot run a wider length rear end.
    Has anyone got anything, or any suggestions?
    Cheers - Grant
    Glenn ke_70's Avatar
    Clay
    Barossa!
    rn25 hilux is g series and shorter than a corolla.
    mx11 i think f series is the same length as corolla, bit harder to find these though.
    Jake
    Northgate
    Like I said to you on facebook, they won't be real easy to find spares for, the hilux diff that I was selling was only 10mm a side wider and they can be picked up for dirt cheap if you look around the one that I am nearly finished converting now cost me $200 with a 3.9 ratio, last one I bought before that was $300 though with a 4.3 ratio.
    Grant
    Gold Coast
    Ahk yea I'm just trying to avoid any increase cause my guards are maxed out and scrub as is
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Quote Originally Posted by ke_70 View Post
    As he said, the only Toyota brand diffs that are remotely available in this country which are the same or shorter in length are the:
    RN25 Hilux - G series (8.0in CW) - 5x114.3 PCD
    MX13 Corona MKII - F-series (7.5in CW) - 4x114.3 PCD
    MX23 Corona MKII - F-series (7.5in CW) - 4x114.3 PCD
    I think I have seen an oddity Corona MKII which had an E-series
    You can see why the Corona diff is so popular, the same length and correct PCD.
    Tarago diffs are all wider.
    Unfortunately all these diffs are super rare and worth a bomb if somebody who knows what they have got are trying to sell it.
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    I have a e series for sale. But in Sydney nsw
    bursting ovaries since 92'
    Grant
    Gold Coast
    Quote Originally Posted by blake. View Post
    How much do you want for it and is it an e292?
    Jun 2009
    Blake
    Penrith
    $160
    I'm not sure, all I know it's I pulled it from a manuel yr20 tarago which is 4.11
    Jake
    Northgate
    Should be able to send it, I got a price to send my hilux diff was about $200 if I pulled it all apart and send the housing, diff center and axles separate.
    Lawrence
    Wollongong
    $160
    4.11 = 92 so that will be E292. It'll still be wider than an 86 diff though. And if you're going to the effort of fitting an E-series diff you might as well get the Tarago F-series out of a YR22 instead.
  1. Hilux rear end or T series LSD rear end for 4AGTE
    By s3phro in forum Technical - Questions
    Last Post: 20th March 2011, 08:07 AM
  2. jdm t series rear end
    By johnk in forum Cars or Parts Wanted
    Last Post: 21st June 2008, 02:11 AM
  3. s-series rear end + cables
    By doridori in forum Car Parts For Sale
    Last Post: 30th December 2007, 11:15 PM
