Results 1 to 10 of 10
Thread: 7 rib big port?
    Nov 2011
    jody
    Queensland
    gold coast
    Default 7 rib big port?
    ok my 4age had uneven compression accross the cylinders
    so i pulled my 87 trueno engine out and stripped it last week
    its a 7 rib bigport with 40mm crank and 18mm piston pin,no oil squirters
    havnt heard of this combo before(7 rib big port-40mm crank)
    could it be the factory engine or a mickey mouse one?
    Veteran stahlz_ae86's Avatar
    Paul
    Wierd, I thought 3 rib were 40mm and all 7 rib were 42mm.
    Nov 2011
    jody
    Queensland
    gold coast
    same,be good to know if anyone else has heard of this
    Veteran Nikkojoe's Avatar
    Tom
    42mm cranks came into the picture mainly in 88, but 7rib blocks came in before that (in 87) so it's possible to have one with 40mm crank.
    The AW11 4age had a 7rib block with 40mm crank according to epc (block change over to 7rib in 08/87 and crank was 09/87 - gze ran same crank from 08/86).
    Nov 2011
    jody
    Queensland
    gold coast
    sweet cheers! now to check vin to engine number(hopefully its the original engine)!fingers crossed
    anyone know where i can do this online?
    Tom
    Quote Originally Posted by whips View Post
    I don't think it is unfortunately. Kouki only ran to 04/87 so it's most likely a 4age long motor replaced into it.
    No way to know unless you have the original books for it (which you probably wont - if that's the case it makes no difference).
    Elite rthy's Avatar
    Leo
    Tulla
    the series 2 AE82 twincams, late mode aw11's and some jdm ae92's came out with the red top bigport 7rib 4ages
    Senior Member Willofan's Avatar
    Jan 2011
    Caringbah
    Put some pics up of the block and crank. My TRD factory race motor is the same combo. Is the motor stamped with R-Dot or TTA on it somewhere??
    Steve
    Stripped a AE92 GTI twincam engine many moons ago and it was as per OP inquiry
    Seemed a small amount of production engine got made like this between bigport and smallport.
    ^^^ this.
    the fxgt also had 7 rib blocks
  1. Throttle body small port to RWD big port manifold
    By grey_nomad in forum Technical - Questions
    Last Post: 6th June 2011, 08:22 PM
  2. Replies: 0
    Last Post: 24th January 2011, 04:26 PM
  3. 7 rib small port block
    By adam in forum Cars or Parts Wanted
    Last Post: 15th July 2009, 08:55 PM
  4. 3rib block with 7 rib(small port) crank?
    By 131-sam in forum Technical - Questions
    Last Post: 26th February 2008, 03:02 PM
  5. Replies: 2
    Last Post: 3rd January 2007, 08:52 AM
