Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 39
Thread: AJPS undercar surge tanks - design updated
  1. #11
    Veteran AJPS's Avatar
    Lonsdale
    some rough instructions
    You will need fuel line about 1 or 2 metres the same guage as the brass fittings and solid fuel lines on your car and a small piece to go between surge tank outlet and inlet for the external fuel pump 8 small hose clamps wiring diagram wire relay etc external fuel pump I used a 2nd hand vl turbo one
    a pair of nuts and bolts and a drill and drill bits to make two holes that these bolts will fit through and a drill bit big enough to drill a hole so the fuel tank strap bolt can fit through I think its 8 or 10 mm..
    Basically get the rear end of the car up off the ground then you have to undo the bolts holding the straps that hold the fuel tank in place and drop it down.
    Place the surge tank up under the car so the brass fittings are on top and pointing towards the middle of the car.
    The bendable strap should now be bent up so it lines up with the bolt hole that the fuel tank strap bolt was in. Mark where the hole needs to be drilled so the bolt can now hold up the tank and the fuels tank strap.
    Now get out from under the car and drill out the hole and get the brass fittings and get thread tape or fuel proof sealant use it on the brass fitting and stick them in the three holes at the end of the tank.
    Get the fuel tank strap bolt and use it to hold the tank in position so you can drill two holes through the L bracket and through the floor (boot) of the car and use the pair of nuts n bolts to hold tank in place.
    Now you will be able to see where you need to cut the hard fuel lines so you can plumb them up to the brass fittings using the fuel line and hose clamps. Now you can sort the wiring and put the fuel tank back in place.
    You will need to have some fuel in the surge tank so the external fuel pump doesnt run with out fuel while the tank is filled by the intank pump.
  2. #12
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    what are the thread sizes for the brass fittings please?
  3. #13
    Lonsdale
    The brass fittings are 1/ 4 x 1/8 male tailpiece
  4. #14
    Sep 2012
    Dude
    Any versions for ST141/RT142 Corona?
  5. #15
    Senior Member turn69up's Avatar
    Apr 2010
    Laurence
    Northside
    Wow! Tig work is amazing would buy just to put on my shelf if i wasnt a poor hobbo
  6. #16
    Lonsdale
    Quote Originally Posted by CHESSEDUDE View Post
    can be adapted to fit
    Quote Originally Posted by turn69up View Post
    yeah its bloody nice
  7. #17
    Sep 2012
    Dude
    [QUOTE=AJPS;933999]can be adapted to fit
    whats required? any pics of ae86 install yet?
  8. #18
    Lonsdale
    fits same as ke70
  9. #19
    Sep 2012
    Dude
    Ok, do you have pics of the install on AE86/KE70?
    You know what needs to be done for Corona?
  10. #20
    Lonsdale
    post number 8 has a fitted pic
  1. UNDERCAR surge tank KE70
    By ke70dave in forum Technical - Articles
    Last Post: 5th September 2013, 03:29 AM
  2. WTB: Shakotan Garage undercar surge tank for AE86
    By schmykel in forum Cars or Parts Wanted
    Last Post: 20th July 2011, 12:39 AM
  3. alloy undercar surge tank for AE86
    By Leigh in forum Car Parts For Sale
    Last Post: 15th October 2009, 11:39 PM
  4. WTB : undercar surge tank set
    By evil86 in forum Cars or Parts Wanted
    Last Post: 26th January 2009, 08:31 PM
