Results 1 to 7 of 7
Thread: Map sensor
    Member Anthony13's Avatar
    Jun 2012
    Anthony
    Yarra glen
    Default Map sensor
    when I brought my 4age it came out of an ae82 corolla and the person that pulled the motor out butchered parts of the loom and they also cut the wires on the map sensor right at the base of the unit and on the other side of the plug so I had no plug for it all, I brought another map sensor with a plug and I've got the wires that go to the map sensor but I'm just a bit unsure of there joining order
    Does it go
    Yellow - yellow
    Red - green
    Black - brown
    Or am I way off?
    You can remove the rubber from the base and depin the pins and add new ones.
    Jun 2012
    Anthony
    Yarra glen
    Yeah I thought of doing that I'm just going to put in a new plug that's why I wanna double check that I'm conecting the right wires
    Steve
    Quote Originally Posted by Anthony13 View Post
    Logic tells me yellow>yellow, Pink>Green, Black>Brown.
    Jun 2012
    Anthony
    Yarra glen
    Yeah that's what I thought just wanted a second opinion tho
    Jun 2012
    Anthony
    Yarra glen
    Thanks to ^^;
    Jun 2012
    Anthony
    Yarra glen
    So I had my map sensor wired in as above and it was running pretty rough and I thought something might of been wrong so I went to pick a part a few weeks ago and found an intact map sensor on a ae82 with said 4age same as mine and the wiring above is wrong it goes!
    Brown to black
    Green with red to yellow
    Yellow to red
    Just tried it and motor runs so much smoother!
  1. MAP sensor
    By Seventy in forum Technical - Questions
    Last Post: 4th November 2010, 03:19 PM
  2. Where is my map sensor??
    By hugh in forum Technical - Questions
    Last Post: 5th December 2007, 08:05 PM
  3. wtb 4AGE Map sensor and throttle sensor
    By ae86driftstyle in forum Cars or Parts Wanted
    Last Post: 22nd March 2007, 08:35 PM
  4. map sensor
    By genkibobo in forum Technical - Questions
    Last Post: 13th August 2006, 11:49 PM
  5. Map Sensor
    By Kapour in forum Technical - Questions
    Last Post: 12th July 2006, 10:37 AM
