Results 1 to 5 of 5
Thread: Knocking noise when turning left
    Mar 2011
    Tony
    St Albans
    AU
    Default Knocking noise when turning left
    Hey Guys ,
    As stated above. This does not happen when i'm tuning right.
    I'm thinking it might be a pillowball mount, but I am unsure.
    Has anyone had this problem before?
    The cars a 86 with no power steering.
    Cheers Guys
    Tony
    Mar 2011
    Ced
    Rowville
    is your entire front end using pillow balls? If your lca is still using ball joints, then it's most likely worn out.
    Mar 2011
    Tony
    St Albans
    AU
    Yes they are. I'll check them out, i know the tie rod end ball joints are worn out, but dunno if they would cause the symptoms.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    so turning when your moving??? sitting still???? when you initially turn, constantly while turning
    Mar 2011
    Tony
    St Albans
    AU
    I'd say, when i'm entering a corner, initial turning of the steering wheel.
  1. 4agte tapping/knocking noise
    By _wanna-be_ in forum Technical - Questions
    Last Post: 4th September 2012, 01:52 AM
  2. whine in steering when turning left
    By blake. in forum Technical - Questions
    Last Post: 26th October 2009, 07:32 PM
  3. more lock when turning left than right
    By ae86 slide in forum Technical - Questions
    Last Post: 8th May 2009, 09:43 AM
  4. knocking/ratteling noise from engine/gearbox..?
    By DRFT - 86 in forum Technical - Questions
    Last Post: 31st January 2007, 04:14 PM
  5. Steering heavy when turning left ?
    By HiLtOn in forum General Topics (No Technical Questions)
    Last Post: 3rd August 2006, 01:33 AM
